beerviper and others who were (are) supercharged! question
Old Aug 8, 2010 | 11:48 AM
ezpotato's Avatar
what fuel pressure are you guys putting out? I know i know it depends on injectors, ems, etc, but i wanna get a range. PSI or bars is fine.
Old Aug 9, 2010 | 03:50 PM
BeerViper's Avatar
I dunno if my fuel pressure has ever been measured per se? I'm still running a STOCK fuel pump and STOCK injectors along with the Vortech FMU. If you read that link you will see that if you're using larger injectors then you may need to make adjustments. Since I'm using the Vortech setup as it was designed (direct bolt-on without changing anything else out) with the full kit, everything is working as it should.
If you are running larger injectors and still using the Vortech FMU, you might need a recalibration kit or additional bleeder valve if you are having issues still...
Old Aug 9, 2010 | 04:01 PM
r1forever80's Avatar
Emad is running turbo xs i believe. His fuel pressure went from 5 to 3 after the fuel return system was put in. Im sure he is trying to see if he is running too lean.
Old Aug 10, 2010 | 12:54 AM
ezpotato's Avatar
that is exactly what i'm trying to do. you dont have a fuel pressure gauge beerviper?
Old Aug 10, 2010 | 11:05 AM
BeerViper's Avatar
I don't have ANY gauges!
Old Aug 10, 2010 | 11:25 AM
FastDontLie's Avatar
...we dont need roads...
I am running walbro FP, 750cc injectors, Stage 1 fuel return, Utec. Out of boost my fuel pressure roughly sits around 36-38 psi.
Old Aug 10, 2010 | 11:38 AM
waijai's Avatar
i.love.gold
I never had a fuel return system/FPR, so I never kept up with my fuel pressure.
Old Aug 10, 2010 | 12:35 PM
acidjake75's Avatar
SOLID...
Old Aug 10, 2010 | 04:00 PM
ezpotato's Avatar
okay my car sits at about 2.9 bars which is aprox 42psi....
god it used to sit at 5 bars, which was 72 psi.... jesus.
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
jbelf23
Forced Induction
Oct 24, 2015 12:32 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
