SPC camber kit
Old Apr 6, 2011 | 03:07 PM
g35man04's Avatar
CLUB MODERATOR
Originally Posted by r1forever80
My specs r based on my ride height mister. I could b rockin +3 camber but I didn't buy a monster truck
in the front when your fully dropped your -1.1 or where you ride at your -1.1???
Old Apr 6, 2011 | 03:09 PM
r1forever80's Avatar
When I am dumped I guestimate I'm at -3 camber. On my ride height of my sideskirt bein 1" off the ground my front camber is -1.1
Old Apr 6, 2011 | 04:45 PM
BeerViper's Avatar
Originally Posted by g35man04
Honestly the Kinetix I have heard that samethign about them snapping at the welds.....Jon being how low I am I cant adjust my upper camber arms unless suspension removed so mine are set all the way out right now.
I actually just got back from Firestone from getting re-aligned again and my front camber was -1.9 and -1.8 with how low I am slammed..still not to bad.
All the talk about Kinetix arms snapping is really old news from their design about 4 years ago....
I'm not super low in the front right now and currently sitting at -0.9 with the Kinetix arms. If I were to go lower I can back out the camber bolt to re-adjust and go more positive.
With these a-arms, I am able to change the camber about a degree negative with 2 full turns of the camber bolt which I can do with a jack and a couple wrenches on the morning of a track day - without removing the wheel!
Old Apr 6, 2011 | 04:48 PM
Hey jon I can change my camber up front without a jack, all I got to do is hit a switch. Lol just messin with ya. Didn't jason reccomend the kinetix?
Old Apr 6, 2011 | 04:53 PM
BeerViper's Avatar
Hey Stephen, I spent less than 300 on my camber adjustment - how about you
Yeah JasonZ-Ya highly recommends the Kinetix arms - he talks about all the a-arms in his suspension 101 thread on my350: http://my350z.com/forum/brakes-and-s...ion-101-a.html
Old Apr 6, 2011 | 05:30 PM
Buju On Friday's Avatar
What about the Ichiba front A-arms? I never hear that much about these, but they are a decent price.
I am dropped up front 1.8" on springs and I am out of spec about 1 degree. will these get me back in spec? (And I don't track, so I don't care about ease of adjustment)
Old Apr 6, 2011 | 05:50 PM
almost3flips's Avatar
That's good to hear then BeerViper. I will have to look into the kinetix front arms now
Old Apr 6, 2011 | 07:35 PM
Ichibas are fine. I ran them for awhile. They are copies of cusco and can b modified to get a lil more positive camber.
Hey jon I only spent 450 on my front and rear spl v1 arms. Although I do have over 3k in my suspension only
Old Apr 7, 2011 | 06:38 AM
johnnydarko's Avatar
beerviper - did you have to do any modifications to fit the kinetix arms?
Old Apr 7, 2011 | 09:03 AM
BeerViper's Avatar
Nope, they were plug and play at my current height.
The hardest part was getting the 2 long bolts that hold the arm out and then back in between the spring without unbolting the shock tower from the engine bay. If I were to do it again, I would probably unbolt the shock tower.
Depending on your ride height, it is possible to back out the camber adjustment bolt too far which would then rub against the sheet metal inside the top of wheelwell.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
jsimonk
Steering & Suspension
Sep 2, 2015 03:07 PM
