Suspension Question
Old Aug 6, 2011 | 07:12 PM
mealad's Avatar
Suspension Question
So, currently I have an 03 sedan that has non-sport springs and tokico blues shocks. Can I run G35 coupe sport springs on my tokico blues or is this not a good idea? Thanks in advance.
Old Aug 6, 2011 | 07:13 PM
Deemo's Avatar
you should be fine.
Old Aug 6, 2011 | 07:23 PM
r1forever80's Avatar
Like deemo said you will be fine. You can run any coupe, z or sedan springs u want but your shock life will lower a tad due to the constant compression
Old Aug 6, 2011 | 08:44 PM
Chief.Crappin.Squirrel's Avatar
run the Z springs...IMO those look the best out of the coupes Z or G
Old Aug 7, 2011 | 12:51 AM
mealad's Avatar
Oem 2003-2006 sedan non sport spring rates
283/308
Oem 2003-2006 sedan sport spring rates
314/342
Oem 2003-2004 350Z spring rates (unrevised suspension)
314/342*
Oem 2005-2008 350Z spring rates (revised suspension)
314/427"
Oem 2003-2007 G35 coupe spring rates (car's delivered on oem 17/18 inch wheels)
314/342
Oem 200502007 G35 coupe spring rates sport suspension (oem 19 inch wheels)
314/427"
What's the difference between the z springs vs the coupe sport springs?
Old Aug 7, 2011 | 12:53 AM
Half an inch shorter all the way around
Old Aug 9, 2011 | 12:47 AM
mealad's Avatar
Is there any benefit to upgrading to an oem spring with a higher spring rate without dropping the car? Or is best to drop the car and get a higher spring rate with my current setup?
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
