Toe Bolt install
Old Sep 22, 2011 | 08:03 PM
dpattana's Avatar
Toe Bolt install
I had a camber kit installed back in April but had no need to install the toe bolts since they were in spec. I had another alignment done today and now they are out of spec. Has anybody had any experience installing toe bolt or does anybody know where to get them installed. This is for a 2011 G37 sedan.
Old Sep 22, 2011 | 09:41 PM
r1forever80's Avatar
its pretty easy aslong as you have a dremel or some sort of bit to elongate the holes
Old Sep 22, 2011 | 09:58 PM
dpattana's Avatar
Unfortunately I do not have access to a dremel.
Old Sep 22, 2011 | 10:34 PM
SuperCleanG's Avatar
Go buy one. It will be cheaper and a Dremmel is a must have tool
Old Sep 22, 2011 | 10:39 PM
G2FLIP4's Avatar
everything
Dremel or a die grinder are your best bet.
Its pretty straight forward. Elongate the holes about 3/16"-1/4" towards the inside of the car and put the new bolts in. Then go get an alignment
Old Sep 22, 2011 | 11:00 PM
dpattana's Avatar
Which Dremel do you recommend?
Old Sep 22, 2011 | 11:07 PM
G2FLIP4's Avatar
everything
A dremel is a dremel. You need a carbide metal bit to grind the aluminum.
I used a die grinder where I used to work. Ground it like butter.
linedr89
Aug 17, 2015 05:11 PM
EPG35
Aug 16, 2015 04:52 PM
CrazyLogic219
Aug 13, 2015 06:40 PM
jimNC
Jul 25, 2015 05:47 AM
