My Dyno - 2005 G35 Coupe 5AT
Old Nov 14, 2005 | 06:03 PM
TedRuxpin's Avatar
I went to Velocity Motorsports today to dyno on the DynoJet. I've got the
19" OEM Tires.
Here are the results.
1) 230.23hp / 219.60 tq (done in 4th gear)
2) 233.47hp / 219.73 tq (done in 3rd gear)
3) 234.95hp / 222.30 tq (done in 3rd gear)
Jason only ran the dyno from 4K to 7K (redline).
Mods I have: (1) UT Carbon Fiber G Tube with K/N Filter and (2) Gordgee's 10 Wire Grounding Kit.
I believe these numbers are pretty standard. I plan to Dyno again after the
(1)Crawford Cats install and again after (2) DC Headers; JIC Y Pipe; Fuji Exhaust. That way we all can see if there is any improvement.
Old Nov 15, 2005 | 02:16 AM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
nice #'s...when are you doing those mods?
Old Nov 15, 2005 | 02:17 AM
TedRuxpin's Avatar
Randy, the crawford cats should be here Friday. But since the dyno/bbq is saturday, they can't put them on then. So hopefully before Thanksgiving. If not, then it will be after Thanksgiving in December. I've already got the Y Pipe and headers on order. I hope to have everything in by January 2006.
Old Nov 15, 2005 | 02:57 AM
G35StrongMan's Avatar
Thumbs up
TedRuxpin,
Good numbers mine were really low bone stock, Chrome factory 17"
215.46 HP _ 216.48 FT-LB
217.68 HP _ 219.47 FT-LB
220.97 HP _ 221.67 FT-LB
Any muffler shop could install the cats, they're bolt-on. They just need to know to bend the heat shield on the passengers side.
Old Nov 15, 2005 | 03:03 AM
TedRuxpin's Avatar
I already talked to Jason at Velocity. He quoted me 2 hours. I'll probably just go there. I didn't dyno my car bone stock unfortunately. So I'll do 2 more dynos to see the changes. I have the 19" and they were at 35psi if that makes any difference.
So is it only the heat shield on the passenger side which must be bent or is it both shields?
Old Nov 15, 2005 | 03:24 AM
Looking through this thread both sides may need to be massaged.
https://g35driver.com/forums/showthr...crawford%2Bcat
Old Nov 15, 2005 | 09:53 AM
hyperlitesmu's Avatar
2 Cars......2 Turbos...
When I got my test pipes on with the exhaust the first thing that happened was the test pipes knocked up against the heat shield on the passenger side. StrongMan speaks the truth. They bent the heat shield away and I haven't had a problem since (3500 miles later) It won't hurt anything, but DAMN it's really annoying.
Old Nov 15, 2005 | 10:56 AM
a.k.a. RANDYS_G
Ted, we could install the cats at the Dec 3rd BBQ at my house if you want...let me know.
Old Nov 15, 2005 | 07:53 PM
TedRuxpin's Avatar
Randy, Wow..that's awesome. Thanks for the offer. Do you have a lift there?
Old Nov 16, 2005 | 01:14 AM
a.k.a. RANDYS_G
I have a jack and someone could bring jack stands...but I thought about it...aren't you dynoing the car this Sat? If so, you'll prob want them installed before that, right?
Old Nov 16, 2005 | 01:28 AM
TedRuxpin's Avatar
No im going to dyno it whenever. its only $40 to dyno. This sat there will be too many people. it takes 45 mins to dyno there. And I may not have it till fri/sat.
Old Nov 16, 2005 | 11:19 AM
a.k.a. RANDYS_G
Ah man! I was thinking about going Sat. Well, if you decide to bring it to my house to have done, we'll need to make sure we have all the right tools. There will be plenty of able bodies there to help out. If you could check to see which tools are needed for the job, I'll provide the garage and the jack...BTW, the O2 sensors in the stock cats require a special DEEP socket...keep that in mind in your research.
Old Nov 16, 2005 | 07:00 PM
TedRuxpin's Avatar
Yea, I may just get it done next Tuesday at Velocity. They mentioned they have done some Crawford Cats on both Zs and Gs before.
Old Dec 4, 2005 | 06:57 PM
fx45copper's Avatar
40.00 damn...Last time I checked to get my old Fx45 dyno'd a shop quoted me 200/pull. Maybe cause it was AWD? anyone know of dyno's in tampa area?
Old Dec 5, 2005 | 12:35 AM
arjunz's Avatar
Great numbers for a 5AT
laksjd84
Feb 28, 2026 01:58 PM
Blakelyg35
Aug 15, 2015 12:12 PM
lemmy999
Jul 25, 2015 12:13 PM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
