Anyone know how to change the xenon bulbs?
Old Apr 12, 2006 | 04:01 PM
BeerViper's Avatar
Just got a set of Philips Ultinon 6000K bulbs and went to throw them in last night not realizing that there is zero room behind the headlamp enclosure to pull the bulb out. I searched for a DIY but didn't come up with anything but '06 projector retrofit...
The service manual says you have to drop the front bumper then unscrew the entire headlamp assembly and remove it. Is there any other way to do it besides this?
Old Apr 12, 2006 | 04:20 PM
waijai's Avatar
i.love.gold
You can go through the wheel well. I changed mine out before. Might be able to help you this weekend.
Old Apr 12, 2006 | 04:36 PM
g35rcr's Avatar
take your wheel off and take the liner off...or you can turn the wheel all the way to the right for the driver side and pull the liner down and repeat but backwards for the passenger side...make sure to wear clean gloves when handling the bulbs
Old Apr 12, 2006 | 05:30 PM
hyperlitesmu's Avatar
2 Cars......2 Turbos...
OMG!!!! It's the upgraded headlight mod....SWEET!!!! That'll put your car in the 10's for sure! Congrats on that.
Old Apr 13, 2006 | 12:02 PM
theeggman's Avatar
That was one of my first mods. Thru the wheel well g35rcr is correct.
Old Apr 13, 2006 | 08:49 PM
JJs G's Avatar
i put some PIAA bulbs in my clearence strip because the stock bulbs suck hand downs... no offense or anything... and i just simply turned my wheels for each side giving me some more room to work with... pull back the fender liner and got to it just like that itll be the same process here.... and BTW because of the small ammount of space... its a pain in the @55 to turn that black circle thing you have to remove from behind the head light... just letting you know...
Old May 1, 2006 | 04:24 PM
BeerViper's Avatar
Well big props to JD!!!
During our last meet at Posado's on 4/21 I was showing everyone the cloudiness that forms over the headlight lens cover and turned on the lights. I still had not installed the Ultinon 6000K bulbs I purchased from someone on the forum.
It was at this point when JD walked over and told me that the reflective housing inside the lights had a crack and is a defect. He said just bring it into Grubbs and they'll replace it. So last Thursday I went into Grubbs to have them fix one other warranty item and mentioned the crack in the lights. When I picked up my car later that evening it came out with brand spanking new headlight assemblies on both sides, with all new bulbs pre-installed!!!!!
So where this leaves me now is with 2 Philips Ultinon 6000K xenon bulbs that I don't really need anymore ... anyone interested?
Old May 1, 2006 | 04:45 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
Jon, glad to see you start taking OWNERSHIP of that damn car. No more (Randys_G) in your sig. Good luck on the sale.
Old May 1, 2006 | 04:50 PM
Melissa's Avatar
I'm going to have to have a talk with him... He's supposed to be my little, mexican worker bee!!!
Old May 1, 2006 | 05:08 PM
BeerViper's Avatar
Yes Randy, the grace period is over and it just feels right to call her mine now. I will probably throw the bulbs up here on the boards where I got them in the first place.
As for that issue I was telling you about ... I found out some new info on it today, booger has been helpful as usual over at my350... http://my350z.com/forum/showthread.p...65#post2351665
Old May 1, 2006 | 05:10 PM
BeerViper's Avatar
It's May 1, 2006 ... he's got the day off
*runs*
Old May 1, 2006 | 05:15 PM
Melissa's Avatar
*runs*
He didn't request it off... he's fired!!!
as25656800
Aug 9, 2015 07:25 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
