Drag NHRA, IDRC, IHRA, NDRA
quarter mile problem
Old Oct 1, 2007 | 04:08 PM
protocolx219's Avatar
i just checkout that the non awd g35 sedans weigh from 3400 lbs to 3500.awd that i have weighs 3740 lbs(i know this because i weighed it at my job that has a scale for garbage trucks).on youtube i saw a g35x video and people commented about the launching and governor of the g35x. infiniti made it to be a safe vehicle.thats why throttle is really slow .thats what they said on youtube.
as for the psi i always have and make sure they r at the recommended psi of 30 psi.i always keep it that way.
i guess ill follow what they said on youtube. just turbo it and thats it.
awd and auto i cant to a burnout
Old Oct 1, 2007 | 04:15 PM
mackinnr's Avatar
it sounds like you are probably leaving late or not brake torquing to 2000-3000 rpm before you leave. Or maybe your tripping the rev limiter once or twice down the track. Do you go on green or yellow? Essentially you should be sitting at the line with your left foot on the brake and right foot giving it some gas to bump up the RPM's, then the second you see a yellow light you are thumping on the gas and lifting the brake, your reaction time should be within a few hundred seconds and you'll break into the 14's with ease. About 5-10% of the time you might red light, but if you wait until you see green you'll be a second behind the pace. You've got an 06 like mine, I leave it in drive for the 1-2 shift (i tend to bounce of the rev limiter between 1st and second at WOT all the time), then flip it over to manual for the 2-3, stay in it deep and you should trip the rev limiter in 3rd about 50 ft over the finish line.
Old Oct 1, 2007 | 04:38 PM
SoCalTed's Avatar
(OMG) don't rev and dump the tranny ! There are cheaper ways of getting their than buying a new trans.
AWDs are inherently heavier, so that's going against you.
5AT
breathing mods are a must (exhaust, cats... consider headers)
You have to flow from front to rear.
Through dynos, I have discovered that my power-making peak is around 6500 rpm, so that's my shift point, even though my rev limiter was raised to 7100. Discover yours, but that is hard since there are not many AWD dynos around.
Here are some suggestions that won't cost you much:
*Run on a cold night with less than a 1/4 tank of gas.
*Pull the spare.
*Pull the jack.
*Pull your spare change under the seats (save for next mod)
*Reset your ECU
*Run without the plenum cover, and put a bag of dry ice on it between runs.
When launching, I don't "power brake", but do bring my revs up to 1200-1500 rpms.. VDC off. I also run my heater on high while coming to the line and staging.
Good luck.
Old Oct 1, 2007 | 04:39 PM
ma_sha1's Avatar
Unfortunately,
You are not that far off from what the stock X performance.
The X is 300lb more weight.
I have 05x, same car as 06x.
My best time before FI was 14.8
This is with:
17" 17lb light Forged wheels (Roja Formular 7)
Z tube
Spare off, jack off, all mats off.
VDC off
1/4 tank of gas
AC off.
60 degrees
ME 0.5" spacer
launch at 1500 -2500 rpm
Manual shift near red line
Nothing I did with bolt-ons really helped much, if anything at all.
FI was my only way to move this pig, I got 13.2 with HKS S/C, now my pig flies
but do u have awd?and whats ur 1/4 mile times?
Old Oct 1, 2007 | 04:42 PM
ma_sha1's Avatar
Did you not read my post?
Old Oct 1, 2007 | 04:46 PM
ME 0.5" spacer
what is that^.
i saw ur pics of ur g sedan.nice work.
btw how much did the dealer charge u for 19 hours of labor.(i didnt know dealers install s/c)only closest infiniti dealers are lynnes infiniti at bloomfield nj and infiniti of manhattan ny .
Old Oct 1, 2007 | 04:47 PM
SoCalTed's Avatar
here's a list of posted G35 times on dragtimes.com
Old Oct 1, 2007 | 04:54 PM
ma_sha1's Avatar
Originally Posted by protocolx219
ME 0.5" spacer
what is that^.
That's 1/2 inch Plenum Spacer by Motordyne Enginering.
Dealer usually won't do it, this is a rare case. The install was ~$2000.
Virus's Avatar
Originally Posted by UltimateGee27
any G regardless of what year should be running 14s - high 14s
Maybe there is something wrong with ur car...a 15.2 is maxima territory
That's even slow for Maximas. My 2k2 Auto Maxima with just CAI and Y pipe ran mid 14's and I'm a pretty large guy.
Old Oct 1, 2007 | 05:05 PM
how much will they charge for a stillen exhaust?
Old Oct 1, 2007 | 05:09 PM
btw.do u guys go to the dealer for maintanance? i dont go anymore.i just change my oil and oil filter every 3000 miles. could anti- freeze affect performance? since it hasnt been changed since march.could this keep the engine hot and affect my cars performance
Old Oct 1, 2007 | 07:53 PM
JfromTheBay's Avatar
i have an 06 G35 sedan 5at and i went to infineon and ran a 14.7 with no mods at all unless the 20% tint unleashes some horsies.... i got some pretty good launches in and could probably do better if i had more runs ....it sounds to me like you dont know how to launch well....i practice some times all i do is sit on my street turn off my VDC and hold down the brake and hit the gas until i feel the wheels braking away from the street i memorized what rpm that is at and ive gotten a good hang of letting go of the brake at the right time...good luck
Old Oct 1, 2007 | 07:57 PM
ma_sha1's Avatar
I go to dealer fir bigger services. 15k, 30k etc. I don't think anti- freeze affect performance, haven't changed mine for 2 yrs. It's time though.
Old Oct 1, 2007 | 08:35 PM
  #30
maximumvette's Avatar
Someone earlier said your reaction time is related to your 1/4 time. This is not true as your time starts when you leave the starting line. I agree, maybe its the high temp weather.
