Drag NHRA, IDRC, IHRA, NDRA
Drag radial questions
Old Feb 2, 2006 | 07:10 PM
trey.hutcheson's Avatar
I started looking at Drag Radials today. I went to tirerack and looked at the BFG T/A's. So here's what I came up with:
I'm thinking about getting the 205/40/17's, and putting them on Cheryl's stocker 04 wheels. The stock tires on her 04 were 215/55, so the DR's are only 10mm skinnier. They also have a tire height of 23.5 inches, versus the stock height of 26.3 inches. This is a difference of roughly 10%. Also, the DR's weigh in at 20 pounds, versus the stock weight of 26 pounds, so the new tires would show a weight loss of 6 pounds each.
So here are my questions. First, am I crazy in assuming the 205's will fit the stock 7" rims? Second, are there any flaws in my belief that the 10% shorter ride height will be similar to going from my stock 3.5 gears to the 3.9's? And last, can anyone recommend really light wheels to run in the rear, preferably 17x7?
And before anyone questions my choice in tire width, let me explain. 205 is only 10mm skinnier than the stock tires. I really don't think this extra 20mm(both tires combined) is going to hurt me. If BobbyD can pull low 2.0's on his stock turanza el42's (215/55/17, *crappy* "standard" all season tires), then I'm bound to get decent launches off this setup.
The only thing that worries me is I have no idea how to properly pre-stage/warm the tires/do a burnout. Gotta learn sometime...
Old Feb 2, 2006 | 07:31 PM
Ninja350Z's Avatar
Enkei
Enkei RSM 15.7 lbs
Old Feb 2, 2006 | 11:27 PM
Cool. Thanks man.
Old Feb 4, 2006 | 12:36 PM
DaveB's Avatar
That's way too short. Stick with a tire that's close to stock height. You need that sidewall to flex a little on launch and a 205/40&17 isn't going to give you that.
Old Feb 6, 2006 | 11:26 PM
FastDontLie's Avatar
...we dont need roads...
I actually have the same question about pre-stage/burn out & launching. I am looking into getting NITTO's NT 01 drag radial. A shop has offered me a pretty good deal for the wheels & tires. So if anyone has any experience w/ the NITTO's please let me know on their performance.
Thanks
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
erich2780
Sep 3, 2015 03:23 PM
