Trassmission upgrade question.
Tee Hee Hee.......... Lookie what I found. This guy is a nut but he knows his stuff!!! I'm still looking for the link I promised but this is a little switch he made up the gives you full line pressure at WOT only. So you're daily driving doesn't suffer. He claims the tranny doesn't heat up like the normal shift because of the quick shift (less time for friction). Give it a look. Hey 12 sec run for N/A........ not bag at all.
click here
I'll still look for the other link. Have a look at his Video of the tranny kill
click here
Ok I found some more stuff for you. This was taken from a link from 2004 but is still up and running. Below is the company info. Have a look and see what you think and yes I'm still looking for that link. LOL
COMPANY NAME J MO OF AMERICA, INC.
ADDRESS 709 W. Commonwealth Ave.
Fullerton CA 92832-1612 USA
PHONE NUMBER 714-738-0621
FAX NUMBER 714-738-1720
HOMEPAGE www.jmousa.com
Originally Posted by ISMSOLUTIONS
You'll want to get a grounding kit for sure. PM SUNDEVILJAY and save a few bucks for a great kit that works just as well as any other, but for about $100 less.
Rick
Rick
As a skeptic, I tried the Sun Auto kit first, deciding to go with a big name that's in all the mags. Then I switched to Stillen hoping a kit designed for the car by Nissan specialists would be better. It wasn't. Having the opportunity to sell my other kits, I decided to thoroughly research the kits, and decided on GroundingGear, for the best of both worlds. And for their R&D promo pricing, the difference is only about $30, not $100 from what what your friend is banging out of his garage. And yes, there is a difference, based on the ones I've tried.
Originally Posted by deadmanincbh
Tranny upgrade I talk about is the tranny software being upgrade to a newer firmware. But what I wanted to know was if we could use the 05+ firmware on our cars and if so how can we do it.
Is the more wires the better?
I asked Gord (GroundingGear) if I should add a few more wires, and he said that I could, but wouldn't suggest it. He did testing up to 14 or 15 wires, and found no difference. He even offered the extra wires to me at a very attractive price, but suggested that I save my money. So I thought, do I just want bragging rights just for numbers, or an actual tested and proven System?
I'll stay at 10 until R&D proves otherwise.
GG was the first to go beyond 6 wires, and now it seems that everyone is playing copy-cat to make a fast buck.
Originally Posted by ckg35
What, you've tried all the others? Or is it just that his kit works well on your car?
Originally Posted by Kensi
... so whats better? lol.. how come no one meationed about 3.9 final drive.. im really intersted in that.. ehh RICK
Completely changes the way the cars runs. Very fast off the line and hitting target powerband areas at every shift. However, as this thread is about improving shifts, and gears don't do that, I left it out.
Rick
I don't think the fact that the TCM is inside the valve body makes for better shifting. It's more about the specific TCM programming vs where it's located. Unless I'm wrong. If so, please explain.
Originally Posted by helldorado
Everybody seems to be forgetting that from 04.5+, the TCM is built into the valve body. That's a big reason there is improved performance with those models over previous.
I love my gears---yes I do!
Rick
Rick
argh..im still trying to find out where i can do it >< i recently went to a shop "Garage5" down in vancouver, richmond. dont know if u have heard of it before..I asked them about the 3.9 .. they quoted me with the pins and stuff. all cost 1.7k canadian. not including the labour.. so i was like wahh -.- they also told me they never did this mod on a g35 before ..so that made me think twice....however, i really want this mod >
The bottom line is that any shop who can do gear swaps in differentials, can do this one too. you can save some headache and time buy purchasing a fully ready to swap unit from 350EVO.com. When your done, send them the old one as a core. Labor is cheaper and all the shims and hard stuff will be done for you....
You'll end up spending a bit less, as you shop only has to swap pumpkins, and not setup the gears as well. Rick...<!! i dont know what to do =(
Originally Posted by Jeff92se
Swap is fairly straight forward from what I hear. But I don't know what it does to your odo, Navi if you have it, etc.. You do lose the use of your cruise control.
Some of the sites listed I am sorry to say were not helpful. Anyone know what the best valve body upgrade is and where I can get one from? And also what is it suppose to improve shifting crispness, speed or something else?
And the 3.917 swap is great. Only downside is loss of cruise control and slightly reduced mileage because of the higher engine rpm's at highway speed, but the improved acceleration makes up for it. If you're going to consider a swap, also do the differential at the same time. The ring gear you swap surrounds the diff. Saves you a lot of money in the long run on labor.
