Throw Out Bearing
Old Oct 25, 2006 | 08:05 PM
MyGUnit's Avatar
Throw Out Bearing
I just got my JWT clutch and flywheel...
Im getting it installed at the dealer.
Will the dealership have a throw out bearing to work with my new setup?
Are throw out bearings universal?
Thanks
Mitch
Old Oct 26, 2006 | 11:22 AM
GT-Ron's Avatar
They should have a throw-out bearing, also known as the clutch release bearing. If not, check the local Nissan parts department. The OEM Nissan part that I have (for the Excedy-made NISMO HD Clutch and flywheel) has the part #30502-69F10. For a few more bucks, you might also ask if they have the NISMO Roller-Bearing Needle Bushing (#32202-09500). Not sure how much (or the exact) benefit this will have, but it's cheap and should provide an upgrade over the OEM bushing. It's about the size of a pinky-ring, while the clutch-release bearing is about the size of a hockey puck.
Old Oct 26, 2006 | 11:44 AM
g35rcr's Avatar
if you have jwt clutch it should have a jwt throw out bearing
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
AL8782
Oct 3, 2015 10:26 AM
Claudiu
Sep 26, 2015 01:04 PM
