350Z Rear Diff
Old Jan 5, 2007 | 03:19 AM
MI SO FST's Avatar
350Z Rear Diff
It has a VLSD right? Would I be able to just swap it in my Sedan with VDC and have the VDC working as well? If anyone has done this please help a brotha out!!!
Old Jan 5, 2007 | 04:56 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
yes it has VLSD, VodkaRocket swapped his pumpkin out for a Zpumkin when his car was at its best.
-GP-
Old Jan 5, 2007 | 09:04 AM
04NismoV35's Avatar
what's the diff between the VLSD on the 350z vs. the ones used on the 6mt G35's starting in '04?
Old Jan 5, 2007 | 11:28 AM
bert039's Avatar
I'm going to swap differentials also. There isn't any difference between the 3.5 vLSD diff, found on the 6MT Zs and a Gs. I saw a post on my350z where someone stated that he was able to swap an 06 3.5 vLSD pumpkin into his 03 G without any issues. No other parts were needed, just the pumpkin itself.
The differences between diffs usually come from comparing 5AT to 6MT. 5AT cars will have a 3.3 final drive whereas the 6MT cars will have 3.5 final drives. Also the base model of the Z as well as earlier 5AT Gs do not include the oem vLSD.
I believe the new 07 G sedans have a 3.7 final drive.
If you do not have vLSD currently on your car and are looking to swap in a diff with the OEM vLSD then you will need to get new axle stubs.
Old Jan 5, 2007 | 11:40 AM
ttrank's Avatar
Grocery getter
I can't imagine driving the G without VLSD. I can't keep traction as-is in 1st or 2nd. I even thought about changing to a 3.3 final drive to see if that would help.
Old Jan 5, 2007 | 12:00 PM
bert039's Avatar
I can honestly tell you, it sucks LOL. I don't really drag race anymore but on sharp corners I'll regularly spin my inner tire. I'm suprised you haven't made the switch to a 3.3, being that you had FI.
Old Jan 5, 2007 | 12:10 PM
vodkarocket's Avatar
Modded Member
When I had my swap done at Z Car Garage, they mentioned that my 2005 3.3FD VLSD would only be compatible with a 2005+ 3.5FD VLSD, and that the ones from older years won't work correctly. I don't know if there is any truth to this, but my 3.5FD made me very happy and my OEM 3.3FD is currently on a car that may soon hit 700RWHP.
Definitely a great mod for the money. Just find somebody to swap with you and pay only for the labor...
Old Jan 5, 2007 | 03:15 PM
ttrank's Avatar
Grocery getter
If that goes both ways I may not be able to switch to a 3.3 with VLSD without adding it. Are there any 04' or older 3.3 VLDS's around?
Old Jan 5, 2007 | 03:26 PM
bert039's Avatar
There are a TON of people on my350z who will jump at the chance to trade you their 3.3 vlsd pumpkin for your 3.5 vlsd pumpkin.
Old Jan 5, 2007 | 03:41 PM
ttrank's Avatar
Grocery getter
Ohh good point.
I might need to look into that.
Old Jan 5, 2007 | 04:39 PM
G SEDAN's Avatar
i have heard of cruise not working above a certain speed......if you use cruise control religiously..might wanna look into that as well.
Old Jan 5, 2007 | 04:43 PM
Modded Member
Never had a problem with it.
Old Jan 5, 2007 | 05:18 PM
ttrank's Avatar
Grocery getter
Some do and some don't. I don't use mine much so it's not a big deal.
Old Jan 5, 2007 | 10:46 PM
MI SO FST's Avatar
can I use an manual one or does it have to be from an Auto? I just want a VLSD in my 03 auto sedan!!!!!!!!
Old Jan 6, 2007 | 01:46 AM
ajayjuneja's Avatar
I have the nismo clutch type LSD and 3.5 FD and cruise control works fine. only issues with cruise control occur on early 03 models.
