diff. oil modifier
Old Jan 27, 2007 | 08:03 PM
broker99's Avatar
diff. oil modifier
do I need to add an modifier to the diff oil when I change it?
thanks
Old Jan 27, 2007 | 11:14 PM
LT1 SS's Avatar
Nope you don't need to a modifier to the oil.
Old Jan 31, 2007 | 01:12 PM
Jason@Riverside's Avatar
If you have a VLSD make sure you are using Differential oil not just gear oil... Then you should not have to add any friction additives...
If you have a clutch type LSD, a friction modifier helps keep the noise down...
Old Jan 31, 2007 | 01:33 PM
ttrank's Avatar
Grocery getter
I use the redline 75W90 made for vlsd.
Old Apr 7, 2007 | 05:12 PM
n1cK's Avatar
G35 6MT
stock is VLSD, right?
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
