Nismo Clutch
Old Feb 2, 2007 | 01:27 AM
cloud's Avatar
Nismo Clutch
Is there anyone with a Nismo clutch that does not chatter at all? at 2k rpm/ idle.
I need to know if there exists a silent nismo clutch cause I'm thinking that its my clutch chattering not my flywheel(JUN flywheel, one of the most quiet flywheels).
Old Feb 2, 2007 | 01:01 PM
Andy@Performance's Avatar
Ive seen your other posts and I think Ive replied in them too. Its not your clutch thats chattering and if it is, it was improperly installed. I have the NISMO clutch disc and NISMO pressure plate and I have absolutely no chattering from the clutch. Yes my flywheel chatters but not the clutch. If youre hearing a cement mixer type of chatter and grind and it only makes that sound under 2500 RPM, then its the flywheel.
Old Feb 2, 2007 | 01:19 PM
ttrank's Avatar
Grocery getter
^^+1
There is no chatter from the clutch. My UR flywheel has a little chatter but not bad at all.
Old Feb 2, 2007 | 03:36 PM
bobshuai's Avatar
in that case i think my stock fly wheel chatter also.
Old Feb 5, 2007 | 10:59 AM
GT-Ron's Avatar
Anyone paired a quiet flywheel with the NISMO clutch? I've got a complete NISMO package waiting for install, but hearing that the NISMO flywheel is one of the loudest has me considering other, less-noisy flywheel options.
Old Feb 5, 2007 | 02:30 PM
Jason@Riverside's Avatar
The only Quiet flywheel is the OEM Flywheel...
All aftermarket flywheels are single piece and do not have the dual mass dampend flywheel like stock...
You can use the NISMO / JWT / ACT / EXEDY cluthes with the OEM flywheel if you wish...
I have seen OE flywheels dampers worn after 50K... Ive seen some that lasted longer as well...
Old Feb 5, 2007 | 03:06 PM
GT-Ron's Avatar
I thought I had read that the RPS was the least-noisy of the aftermarket flywheels. Have to look more, but I didn't think it would work with the NISMO clutch. I'd hate to mix-n-match anyway.
Wish I had someone local with the NIMSO flywheel so I could hear it in person. I'd hate to spend so much for the OEM flywheel (especially already having the NISMO flywheel right here) but might do so if the NISMO unit is that incredibly loud.
Hate to just install it to find out, as that labor will contribute even more to the cost of a different flywheel.
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
dseet
Oct 11, 2015 12:40 AM
AL8782
Oct 3, 2015 10:26 AM
