Rogue Engineering Short Shifter Installed
Old Nov 28, 2003 | 02:19 PM
narkotic's Avatar
I installed my rogue engineering short shifter last weekend and it's awesome. It makes the throw perfect, like it should have come from the dealer. Since the lever is longer than stock, it reduces the effort to shift, meaning no more notchyness, it just snicks right into gear. Installation wasn't too bad, it would have been easier if I had a lift, but using one jack stand on one side made it hard to manuver underneath. You have to detach the tranny fork from the lever, but that mechanism is above the drive shaft.. Taking it off and on is easy, but oddly enough putting that damed rubber boot back on is the hardest part. It covers the mechanism from underneath the car. I give this mod an A+..
04' G35 / 6MT / Tein Basic Coilovers
Volk 19" GT-7 Gunmetal
Old Nov 28, 2003 | 03:29 PM
jaxxx's Avatar
Re: Rogue Engineering Short Shifter Installed
can you tell me how much the throws are reduced? like maybe what percent?
and maybe guess how much higher.... i'm guessing just about 1"
I plan on getting this.. where you get it from?
Old Nov 28, 2003 | 04:24 PM
narkotic's Avatar
The shifter is no higher/lower than the stock one. The throw is reduced a good 30%. www.rogueengineering.com/350z i think...
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
RA102223
Aug 15, 2015 09:24 PM
Team STILLEN
Aug 10, 2015 08:17 PM
BasquiatPicasso
Jul 23, 2015 06:26 PM
