5th gear grinding
Old Mar 5, 2007 | 10:45 PM
nghiars's Avatar
5th gear grinding
alright... i dont know wats going on with my tranny but i came back from a trip and i took the car to work today.. it was fine when i keft it on friday but when i granny shift into 5th gear during slow speeds, it grinds.. no problem what so ever when im pwoer shifting at high speeds.. anyone else out there with the same problem or any insight.. it would be much appreciated..
Thanks in Advance,
Allan
Old Mar 26, 2007 | 04:09 PM
SmoothieG35's Avatar
Yes, I have the same issue. 5th gear can be quite difficult to get into. Brought it to the dealer and they couldn't mimic the issue as it was intermitent.
Old Apr 10, 2007 | 05:34 PM
nghiars's Avatar
they ended up finding mteal chunks in the tranny oil so they replaced the wole tranny under warranty
Old May 1, 2007 | 12:05 PM
virtualbong's Avatar
I didn't think you could bring in your car for grinding issues. Whenever I go into 5th gear it grinds. I think there was only one time where I didn't have it grind on me. So you guys think I can bring it to the dealer?
Old May 1, 2007 | 12:34 PM
VQguy's Avatar
I would suggest taking it to the dealer. I've heard of something like this with older Toyotas. Apparently the 5th gear synchros are the first to let go after long term use, don't ask me why exactly. Be sure to check the fluid level in your tranny and change it out when recommended.
Old May 1, 2007 | 12:54 PM
Just called up a recommended dealership...its not looking too optimistic. I probably will still bring the car in. How much do you guys expect a clutch replacement or transmission replacement cost?
Old May 1, 2007 | 01:00 PM
ttrank's Avatar
Grocery getter
There is a BIG problem with the synchros. Nissan has replaced 1,000's of tranny's because of this. I'm on #2. Make sure you get a replacement under warranty.
If you search around on here and on my350z you can find how many people have had this issue. Some guys are on their 4th or 5th tranny.
Old May 1, 2007 | 01:10 PM
I'm pretty new to manual transmission cars. Can anyone provide a decent link to this issue so that I can read up. Thanks!
Old May 1, 2007 | 01:14 PM
ttrank's Avatar
Grocery getter
The best bet is to go over to my350z and search for synchro. There is a long, long thread over there.
magnetism80
Feb 1, 2019 10:00 AM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
alinero718
Sep 27, 2015 09:35 PM
edwinisdumb15
SOCAL Meetings & Events
Sep 18, 2015 06:46 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
