Transmission Fluid Flush
Old Mar 23, 2007 | 03:32 AM
HerG35's Avatar
How many quarts of transmission fluid does it take to flush the transmission?
Old Mar 23, 2007 | 01:35 PM
Jebsleo's Avatar
Varies. Not sure why. I just did mine at the dealership. Set me back $245.00 CDN.
Old Mar 23, 2007 | 02:08 PM
g35rcr's Avatar
manual or automatic?
Old Mar 26, 2007 | 03:25 PM
HerG35's Avatar
Automatic
Old Mar 26, 2007 | 05:38 PM
sliderg35's Avatar
The dealer told me they use 10.5 l when doing a flush. I drained and replace mine with only 3.5 litres.
Old Mar 27, 2007 | 03:13 PM
Drewer's Avatar
I hope the dealer did a complete system flush for you then. Otherwise they are screwing you. How lame! This is taken directly from the G35 maintenance manual:
* When the color of the fluid coming out is about the same as the color of the new fluid, the replacement is complete. The amount of new transmission fluid to use should be 30 to 50% of the stipulated amount.
^^(page MA-20)
A/T fluid: Genuine Nissan Matic J ATF
Fluid capacity: 10.3 l (10-7/8 US qt, 9-1/8 Imp qt)
^^(page MA-21)
Note the 30 to 50% of total? Last two times they changed my A/T fluid, the used 5 and 4 liters respectively.
-andrew
g.spot
May 9, 2016 10:54 PM
f22raptor
Mar 18, 2016 08:50 AM
AL8782
Oct 3, 2015 10:26 AM
