6MT Oil Change?
Old May 1, 2007 | 12:37 AM
Nickk6's Avatar
6MT Oil Change?
How often do you guys with a 6mt change your oil? I tried searching and I know what the manual says, I just want to see what you guys do. I have 41k now and have not changed the oil, its starting to get notchier as the miles add on, so I plan on changing soon. Any suggestions as to what oil to use as well? tia
Old May 1, 2007 | 01:28 AM
IPM6G's Avatar
Use Amsoil
Old May 1, 2007 | 01:35 AM
Nickk6's Avatar
Is changing the oil every 30k too much or should I change it around then?
Old May 1, 2007 | 08:14 PM
IPM6G's Avatar
I usually change my oil between 10k or 15k
Old May 1, 2007 | 08:38 PM
Kev G35's Avatar
I'm sorry.. I don't get it.. are we talking about motor oil? I thought it's required to changed around 3750 miles (3k7 miles) according to the manual book??
how can you not change it after 41000 miles (41K)???
Old May 2, 2007 | 06:54 AM
g35rcr's Avatar
Originally Posted by IPM6G
Use Amsoil
try it and see how it feels...nissan will no longer cover powertrain warranties for using other trans fluids...just stick with the nissan fluid ever 30k miles in the trans...the diff you can run whatever you want
Old May 2, 2007 | 06:00 PM
ttrank's Avatar
Grocery getter
I change mine every 10-15k. I do the tranny and rear dif at the same time.
Old May 2, 2007 | 07:15 PM
Skaterbasist's Avatar
Retired SuperMod
Transmission...
At 41k without an oil change his engine would have been scrap metal
11bEMT
May 27, 2022 03:13 PM
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
