ACT street clutch,ACT prolite flywheel review
Old May 4, 2007 | 08:58 PM
cchaorule's Avatar
so i dropped my car off at world one performance in kent today.. just picked up my car.. they put in the ACT street clutch and ACT prolite flywheel... right when i got in i put my foot on the clutch.. i realized that the clutch was really stiff.. i started to drive off.. and i almost stalled it at first... the catch point is almost instant.. i thought the pedal pressure was gonna be softer.. but it was a lot more stiffer than stock.. you have to put a lot of pressure on it at all times.. hopefully it gets softer after i break it in.. but so far i like it... the noise chatter on the flywheel is not bad at all.. althoguh it is noticeablly under 2000 rpms.. but it is nothing that annoys me.. cant even hear it with radio on.. they also replaced my transmission fluid.. they said they use the best..i dont have any knowledge on what transmission fluid is good so i just went ahead and used theres.. they gave me redline lightweight shockproof gear oil.. they charged me 8.50 a quart... ill let you guys know how its working after i break it in properly...
Old May 20, 2007 | 02:12 AM
Jeff92se's Avatar
Red Card Crew
Redline is a quality synthetic that should work well.
As fo the stiffness, If the act is anything like the one I had for my old maxima, yes, the PP is going to be stiffer. You will get used to it.
Old Nov 28, 2007 | 11:06 AM
Manny2ksi's Avatar
where is the follow up?
magnetism80
Feb 1, 2019 10:00 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
bigmike
Sep 17, 2015 01:58 PM
ChickenTendrs
Sep 16, 2015 01:10 PM
jbmw002
Sep 10, 2015 12:54 AM
