click when clutch is disengage
Old Jun 13, 2007 | 08:59 PM
.moO^.'s Avatar
I recently had nismo SS clutch line installed but today i nooticed there is a click noise when I press into the clutch (disengage) and I can lightly feel it on my foot. I did this couple more times while the car is parked & shut off I can hear it from outside. I "personally" don't think it's the clutch line issue as it doesn't really sound like it...
Any idea what is wrong?
Old Jun 14, 2007 | 07:53 PM
Need4SPEED05's Avatar
That was the same problem I had. But my problem happened after I gave it a hard launch a couple of nights before and the clutch got stuck for a bit. My car is completely stock so I brought it to the dealer. They replaced the pressure plate under warranty. After they serviced it, the clutch feel was apparently lighter also. No noises since then. The trannys on our cars really suck. Good luck solving it.
Old Jun 15, 2007 | 01:02 AM
.moO^.'s Avatar
Thanks for the info. I'll call up my local dealer and have them check it out.
Old Jun 27, 2007 | 07:23 PM
chobble19's Avatar
https://g35driver.com/forums/drivetrain/161770-click-pedal-when-releasing-clutch.html
Old Jun 27, 2007 | 08:32 PM
.moO^.'s Avatar
Mine sounds the same thing, except mine occurs when I step into the clutch and not releasing the clutch. Also, when the click occurs I can hear it from the outside as well and I could lightly feel the click on my foot.
I'll take a look this weekend.
Old Jun 28, 2007 | 02:40 PM
yes it only happens when you step into it.
Old Jun 28, 2007 | 06:40 PM
.moO^.'s Avatar
I noticed it occurs easily at a hot weather (hence CA is hot as heck lately). Taking it into dealer to take a look on monday.
Old Jul 3, 2007 | 01:33 PM
.moO^.'s Avatar
After some fight with George @ Tustin Infiniti said they're going to try and replace the clutch pedal assembly...
Not sure if it's pressure plate or clutch assembly.. but if I have issue I'm bringing back to them.....
Old Jul 5, 2007 | 12:24 PM
.moO^.'s Avatar
So I had my pedal assy replaced but click still exist....
I noticed it does it almost every time if I moved the clutch a bit towards brake and step it in... anyone know why it does that?
Old Jul 5, 2007 | 06:52 PM
.moO^.'s Avatar
I need someone's input on this.
Dealer replaced my pedal assembly but it's still doing the same thing. They offered me to talk to the shop foreman personally to discuss this issue to make attempt to satisfy me (clearly I'm not satisfy right now). Can anyone give me an input as to what could be the issue?
pressure plate perhaps?
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
AL8782
Oct 3, 2015 10:26 AM
Jpete
Sep 25, 2015 01:38 PM
jbmw002
Sep 10, 2015 12:54 AM
