AT check light flashing (14 times?)
Old Jun 21, 2007 | 06:17 AM
r32zilla's Avatar
Thumbs down AT check light flashing (14 times?)
Hi everyone,
slowly going out of my mind here......in Australia...
My Japanese V35 300GT 5AT is having a little issue right now.
After about half an hour driving and on a restart there is only ONE gear, as in I place it in D and it will rev to redline if I let it, never changing. If I stop, restart all is well till it feels the need to play up.
On a restart the AT CHECK light flashes for about 14 times..
Any ideas? I have already done the battery disconnect ECU reset and also the timed method to no avail.
cheers
zilla
Old Jun 24, 2007 | 12:06 AM
rcdash's Avatar
the tranny is in fail safe mode. either a sensor is bad. or the sensor is reading something messed up. check the service manual for all the things that might have gone wrong - or take in to the dealer.
have you been flushing the ATF fluid every 2 yrs/30k miles as recommended?
Old Jun 26, 2007 | 05:24 AM
r32zilla's Avatar
Thanks for that. Yes I went to NISSAN dealer and they plugged in the Diagnostic tool then printed off and cleared the errors.
It ran fine till it went into limp home again about 30 mins later.
Do you think its got big problems?
The AT fluid has been flushed recently to try to fix the problem...
Any other ideas?
Old Jun 26, 2007 | 08:59 PM
Jeff92se's Avatar
Red Card Crew
Yeah that's a problem! Something caused those codes to flash! What were the codes??? And what did each code correspond to??
Old Jun 27, 2007 | 08:01 AM
r32zilla's Avatar
Sorry everyone I dont know the codes, it does seem to flash 14 times.
Do you think I need a new tranny?
It does seem to slip under hard accel...
Old Jul 10, 2007 | 12:50 PM
arjunz's Avatar
any update?.. i am having the same problem
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
Muski_G
Dec 1, 2023 11:11 AM
3000vr4tt
Media Share V36 Sedan
Jan 4, 2023 03:20 PM
ghost_g35
Aug 7, 2015 10:31 AM
