Problem with tranny and coolant
Old Jul 9, 2007 | 11:44 PM
insydiusg35's Avatar
Exclamation Problem with tranny and coolant
Today I noticed a weird jerky feeling driving my car. It felt like my transmission was shifting harder than before. I parked the my coupe on the sidewalk and noticed that my front lip on the passenger side was dripping some brown fluid. I checked the fluid and it didn't look like tranny fluid, but rather looks like coolant. As I opened my hood to see what was going on, I noticed that my coolant reservoir had brown fluid on the top and that it was all in my lower side engine bay and under tray plastic covering. I let the car sit for an hour and it stopped dripping. I noticed the coolant reservoir was overflooded with a big layer of what looks like brown coolant, and a lower later of green coolant. I will be taking my car tomorrow to the dealership to have it checked out, but I want to know what is going on, if anyone had this problem as well? Any information would greatly be appreciated.
Old Jul 11, 2007 | 01:32 PM
rcdash's Avatar
Doesn't sound good at all. I'd be worried about a headgasket issue (combustion gases getting into the coolant). Get it checked out and keep your fingers crossed. How was the oil leve?
If it's easy to remove your nitrous setup, you may want to consider that. If you don't want to do that, you may want to have a performance shop check it out first before you go to the dealer and your warranty gets voided.
Old Jul 11, 2007 | 01:34 PM
rlwjr1's Avatar
Assuming the car is an automatic, it's possible the trans cooler inside the radiator blew....
Old Jul 11, 2007 | 11:06 PM
OCG35's Avatar
Interesting thought... haven't heard of that happening but I am curious now to see if that is what happened... OP have you determined anything yet?...
Old Jul 11, 2007 | 11:22 PM
GreenGoblin's Avatar
The goblin resurrection
wow that is strange I would like to know what the outcome is when you find out
Old Jul 11, 2007 | 11:57 PM
rcdash's Avatar
hey good thought given the symptoms - that would be a really good outcome (relatively cheap fix). wouldn't drive it too long with coolant inside the tranny!!!
Old Jul 14, 2007 | 07:54 PM
OCG35's Avatar
OP... any news?... if it is in fact the ATF cooler creating an issue it's going to be good for all ATs to know...
Freeman186
Sep 6, 2023 10:07 AM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
Ohsixgee35
Sep 16, 2015 04:33 AM
Jnm07
Sep 5, 2015 01:16 AM
kevintandmd
Sep 3, 2015 06:41 PM
