Wheres the transmission bolt?
Old Aug 4, 2007 | 02:05 PM
irshadow's Avatar
I've tried searching...I'm trying to do a transmission fluid change on an 05, 6mt. I found one thread w/ pictures, but the pictures are not working and i cant seem to find it again.
Last time i was doing an oil change, i went searching for it, but couldn't find it. Just ended up burnign my hand on some part, lol
Can someone help me out?
ALso, how many quarts do i need? and what tools...i believe it was a socket head bolt?
thanks!!
Old Aug 4, 2007 | 02:06 PM
jjyellow's Avatar
auto or manual
Old Aug 4, 2007 | 02:07 PM
jjyellow's Avatar
may bad, I see 6mt, should be at bottom of tranny toward middle if I remember correctly
Old Aug 4, 2007 | 11:51 PM
Jining's Avatar
its pretty easy to find, are you geting all the way under the car, if so you should easily be able to see it on the passenger side of the tranny? Theres 2, one up high to fill and one thats lower. I believe you need an allen wrench actually a pretty big one, I think its 4 quarts or perhaps a tad bit less.
Old Aug 5, 2007 | 06:36 PM
irshadow's Avatar
So Passenger side, the bolts are probably on the side...not on the bottom?
Old Aug 5, 2007 | 06:39 PM
Jining's Avatar
yea from what i remember its on the side of the tranny, the passenger side.
Old Aug 5, 2007 | 07:03 PM
binar's Avatar
Drain Bolt is on the bottom.
Fill Bolt is on the side... sheesh...
They are pretty easy to see. Crawl under and have a look.
Old Aug 5, 2007 | 07:28 PM
Still2Slow's Avatar
http://www.350z-tech.com/zwiki/Manua...id_Replacement
We have the same transmission.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
f22raptor
Mar 18, 2016 08:50 AM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
6spdGspot
Oct 5, 2015 01:55 PM
