drivers at 6mt, "skipping gears saves gas" ???
Old Aug 10, 2007 | 10:45 PM
  #31
Skaterbasist's Avatar
Retired SuperMod
Originally Posted by Klumzyee
Yeah I skip gears all the time.. WOT 1st, WOT 2nd, WOT 3rd, shif to 6th
._.
I like this style
Old Sep 7, 2007 | 02:36 PM
  #32
stefanzo911's Avatar
Originally Posted by g35john
95% of the time I shift at 2000 rpm. If I happen to slow down, its not uncomon for me to let the RPM's drop to 1400 in any gear. Unless your racing or climbing a steep hill the VQ has always had plenty of torque to keep up with traffic. As a result I average at least 24 mpg per tank, and I believe its one of the reasons im still able to keep the original cluch in the car for so long. I have over 106K miles now.
^^Doing pretty much the same, 2K RPM is a good rule of thumb when shifting, coasting a good idea, and using the brakes as little as possible to optimize fuel economy as well as minimize wear and tear on tires and pads.
By driving "cool" some may achieve easily 22-24MPG in mixed driving.
Hard to stay in that mode 24/7 though when the G is begging to be "handled".
Old Sep 7, 2007 | 02:39 PM
  #33
st1sj's Avatar
skipping gear could save gas, but only if you are gentle on the throttle. if you go 1 to 3 and then mash the throttle b/c you want more pickup, as opposed to 1 to 2 with gentle throttle, it would be counterproductive.
Old Sep 7, 2007 | 03:18 PM
  #34
redlude97's Avatar
I go 1-2-6 occasionally, but its not to save gas, its because of how fast I am going by the end of second already
Old Sep 7, 2007 | 03:54 PM
  #35
Jtrain's Avatar
I drive an SRT8 with no overdrive gear
11mpg on a good tank, 13.5 is my best.
Old Sep 7, 2007 | 04:02 PM
  #36
kvangil's Avatar
+1....I do the same sometimes. If I'm already going 50MPH in 2nd, why row throw 3,4,5 when I'm not really going to accelerate anymore. So--it goes into 6th and I just cruise from there....Contrary to what some people are saying here, skipping gears does not hurt the car. Not sure if it really helps fuel economy that much either though. had a 95 maxima that I drove to 140K miles with a lot of shift-skipping (1-2-5) and never had a tranny issue.
Old Sep 7, 2007 | 04:11 PM
  #37
Jeff92se's Avatar
Red Card Crew
That made no sense.
6 gears is for performance as well as economy.
One gear would definately not save gas.
Originally Posted by TINMAN
whoever told that dude is a dumbass
whoever listen to that dude is a dumbass
they made 6 gears 1,2,3,4,5,6 for a reason...to use them
if that saves gas then they should make only 1 gear for all the cars...that would save 1/6 of the gas bill yes?
Old Sep 7, 2007 | 07:49 PM
  #38
redlude97's Avatar
Exactly, if you are already going 50-60 and have reached your cruising speed, go straight to 6th, do NOT make a stop in 4-5.
sick_sixspeed
Tuner & Dyno
Jul 21, 2015 03:23 AM
driftsucky
Jul 15, 2015 12:38 PM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
