nismo differential
Old Aug 30, 2007 | 08:46 PM
Gfast's Avatar
nismo differential
hey, i have an 04 at
i am thinking of upgrade my differential to nismo differential, but i can't find much info.
i've been searching around too, but not much description about it.
can someone give me some tip or info about this nismo differential?
thanks in advance
Old Aug 31, 2007 | 05:32 PM
ZeeOne's Avatar
Here's a comparision of the various LSD available for the Z. I have the Nismo LSD and I like it. But for some, the chatter from the kicking rubber when turning can be annoying.
It helps you put more power to the ground, when needed.
G
Old Aug 31, 2007 | 10:27 PM
rcdash's Avatar
I'll save you the trouble of research every diff. Your choices I believe are Cusco RS or maybe Nismo with at AT rear diff. Nismo is clunky - not great for a daily driver.
That said, I would (did) upgrade to the 3.5 ring gear (many 6MT owners discard these as they move up) and then pick out either a Quaife if you have an open diff or a ATS/Carbonetics carbon diff if you currently have a VLSD diff (for the sake of install).
These are the top two diffs on the market for our cars.
Contact ForgedPerformance.com - they can help you out.
Old Sep 1, 2007 | 06:13 AM
OCG35's Avatar
there is also Quaife and 3.7 FD
Old Sep 1, 2007 | 12:29 PM
Gfast's Avatar
thanks a lot for the info
Marlin84
Apr 1, 2020 12:52 PM
dseet
Oct 11, 2015 12:40 AM
AL8782
Oct 3, 2015 10:26 AM
