Rear Diff Fluid Question
Old Sep 3, 2007 | 11:04 AM
JC79G35's Avatar
More fun with DIY...
So yeaterday I decided to change my rear diff fluid meself. MISTAKE! Well, it was a learning process at best. I managed to find some tubing to make it easier to get the fluid in. Now I went through two quarts of the stuff. A good percentage - about 1/2 - managed to get on the floor through my trial and error of getting the fluid in. And let me tell you diff fluid reaks to high hell. So I might have got a quart (2 pints in). I felt this might be a little low since the ESM recommends 3 pints. This morning I picked up another bottle and began to fill. It only took about 200 ml before oil started leaking out of the side fill hole. Does this mean I'm full? Keep in mind I only had the back of my car up, so would the fluid fill to the front of the diff case? I'm only asking this because I tried to check the level with my finger as its shown in the ESM, but it did not feel like the oil came up to the hole. I took the car for a drive and it felt okay. Am I good? Please keep in mind I have a base G, so no LSD.
Old Sep 3, 2007 | 11:57 AM
Gordgee's Avatar
Administrator
The diff is full when the oil starts to leak back out of the hole, so it sounds like you're okay. It's funny that you didn't feel the oil level at the lower level of the hole if it started leaking back out however.
Next time, go to an auto tool supplier and get yourself a 'Mechanic's Syringe'. It's basically a big syringe type thing that has a tube on the end of it. You draw up the fluid, and push it back out the tube. Much less messy than using a sqeeze bottle, etc.
Old Sep 3, 2007 | 12:33 PM
DaveB's Avatar
FYI, the diff only take about 1.2 quarts.
Old Sep 3, 2007 | 02:20 PM
Meatshackle's Avatar
Deep Sea Moderator
Like Gordgee said get a syringe/pump. Makes it much easier. They're only like $8, I think I threw mine away after just so it I didn't have to store it for another 3 years until the next time.
Old Sep 3, 2007 | 02:39 PM
JC79G35's Avatar
Thanks guys, I leveled the car out (i.e. had the car up on four jackstands) and when I unscrewed the fill plug, oil started spilling out. Looks like I had too much. I let the extra drain and checked the level. A-ok!
Thanks for the suggestion on the syringe! I also found that using 5/16" diameter clear plastic tubing (about 2' in length) works well if you remove the rear passenger wheel and route the tubing from the drain hole to the upper wheel well.
Old Sep 4, 2007 | 11:19 AM
joe603's Avatar
What kind of oil did you use?
Old Sep 4, 2007 | 01:39 PM
JC79G35's Avatar
Mobil 1 75w90 synthetic. Had plenty of that in stock at Auto Zone.
Old Sep 4, 2007 | 03:53 PM
joe603's Avatar
We don't need to put in any additives?
Old Sep 4, 2007 | 04:27 PM
JC79G35's Avatar
Nope, just gear oil.
Old Sep 4, 2007 | 05:02 PM
joe603's Avatar
last question...is there a crush washer on the drain or fill plugs?
Old Sep 4, 2007 | 06:07 PM
Deezflip's Avatar
yes, i think there's washers but i'm one of the few who leaves and re-uses the previous washer, ...but always check for leaks.
Old Sep 5, 2007 | 08:58 AM
JC79G35's Avatar
I do as well, but I check the washer make sure it does not look all FUBAR'd and then inspect for leaks periodically. But its not as frequent of a change as the motor oil, so it should be okay.
rezendvous420
May 31, 2020 01:26 PM
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
mushu
Jul 15, 2015 03:55 PM
