GMT tranny oil
Old Sep 14, 2007 | 12:40 AM
fast04G's Avatar
Manual tranny oil
what do you all reccomend?? the oem fluid or something like royla purple?? im looking to change my diff and tranny fluid soon. THANKS!!
Old Sep 14, 2007 | 07:00 AM
g35rcr's Avatar
in the trans stay oem in the rear diff motul is nice
Old Sep 15, 2007 | 02:02 AM
fast04G's Avatar
will do, thanks!
Old Sep 15, 2007 | 07:20 PM
Still2Slow's Avatar
Be careful what you put in there. Whatever you decide on make sure it's a GL4 gear oil. If you put a GL5 oil in there, you will prematurely wear and eventually destroy your transmission. Most newer manual cars (Nissan excluded) are GL5 recommended. I don't understand why Nissan choose to place copper in their trannys. Something like redline gear oil would be your best bet. It's what I used for the trans and rear differential.
Old Sep 15, 2007 | 08:31 PM
g35rcr's Avatar
sticking with oem nissan fluid in the trans is the best bet since its synthetic already...the rear diff is not as sensitive
Old Sep 15, 2007 | 11:24 PM
fast04G's Avatar
alrighty, thanks for the heads up on the gl5. thanks for the help!
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
