Will RPS flywheel work with JWT clutch?
Old Oct 12, 2007 | 02:22 AM
acerys's Avatar
Clutch is gone. Need a new set.
Old Oct 12, 2007 | 06:48 AM
g35rcr's Avatar
yes they are both designed off the stock 300z twin turbo clutch...if you ever go oem with your rps flywheel you need a 300z twin turbo clutch kit
Old Apr 9, 2009 | 01:08 PM
tegraphile's Avatar
As of this point, I'm finding out that they don't fit together. Right now, I'm working with the retailer to find out if RPS sent the wrong flywheel. From the combination they sent me, the RPS flywheel is about 3-4mm in diameter larger than the JWT pressure plate out of the JWT clutch kit. This means both the alignment pins and screw holes don't match up. FYI, this is for the 03-04 drivetrain.
Old Apr 14, 2009 | 04:28 PM
Mr_pharmD's Avatar
If u have the RPS flywheel for 350z then u would need a clutch from 300zx tt. Is that what u have?
Old Apr 21, 2009 | 03:47 PM
tegraphile's Avatar
I had the company I ordered the parts from verify with RPS and JWT to verify fitment, and they both told the company they would fit. RPS might have sent me the wrong diameter flywheel and offered to send me the matching clutch to go with, but I didn't have time to wait around for another clutch, so I went with the complete JWT (flywheel/clutch) setup.
jsimonk
Dec 22, 2023 03:49 PM
EPG35
Aug 16, 2015 04:52 PM
TurboEE
Jul 31, 2015 10:41 AM
neight
Drivetrain
Jul 28, 2015 04:47 PM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
