Checking AT Fluid
Old Mar 25, 2008 | 12:38 PM
68_GT's Avatar
what fluid needs to go in for the 5AT ? Or does it have to go to the dealer for a flush ?
talked to a shop yesterday about flushing mine since I have 60K miles now. He said $150 and some import universal AT fluid he uses on Nissans ??
sound normal ?
Old Mar 25, 2008 | 01:35 PM
DaveB's Avatar
sound normal ?
You need Nissan's "J-matic" fluid. There are some companies that make tranny fluids that supposedly meet the J-matic specs, but I wouldn't risk it. Additionally, Nissan doesn't recommend a "flush" with a flushing machine. The FSM procedure involves draining the tranny and then disconnecting the tranny cooler lines, and with the engine on, drain the cooler and torque converter while adding fluid until it comes out clean. It sounds like a messy two person procedure. I think most of DIYers will drain the tranny, drive around a little. A drain the tranny again. This should remove a majority of the old fluid.
Old Mar 25, 2008 | 02:15 PM
68_GT's Avatar
how many quarts does the transmission hold ? how much are they each quart ? seems like draining then adding 10 quarts then doing it again could be a lot of transmission fluid to dispose of and to buy.
thanks for the info
ordering a transmission dipstick now....
Old Mar 25, 2008 | 04:48 PM
sliderg35's Avatar
Originally Posted by DaveB
2003 sedans DO NOT come with dipsticks. All that's there is the cap. I purchased my tranny dipstick for $12 shipped from everythingg35.com.
Mine has a dipstick and I didn't buy it separately?!?!
Old Mar 25, 2008 | 06:05 PM
DaveB's Avatar
Must be a Canadian thing. I haven't heard of any US-spec 2003 sedans that have a dipstick. On the US-spec 2003 sedan, it's just a cap with no provision for a dipstick. On the dipstick caps, you'll notice writing that states in order to check the fluid level, you must install the dipstick backwards so that the bolt hole opening is facing towards the passenger fender. This lack of wording on the US-spec 2003 cap is a tell-tale sign that the dipstick has not fallen into the tranny because there was no dipstick to begin with. The only dipstick is the jerky making that claim
Old Mar 26, 2008 | 09:04 AM
lexusk8's Avatar
thanks for the info
You need about 4 quarts of J-matic fluid for a simple drain and refill. I paid around $45 for 4 quarts at the local Nissan dealer.
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
migurus
Sep 5, 2015 09:39 PM
G35CO
Sep 4, 2015 09:27 AM
kevintandmd
Sep 3, 2015 06:41 PM
TheBay
Sep 3, 2015 03:27 PM
