HELP - Squeeking clutch
Old Dec 20, 2007 | 01:11 PM
Plat04G's Avatar
My clutch is squeeking when i release the pedal from the floor. You can feel it in the pedal and hear it inside but its 5 times louder outside the car. Sounds like its coming from the firewall area, maybe where the cable goes through the firewall. Now the weird part, it only does it on cooler mornings and the humidity has to be high. I took it in for service a couple days ago. I just got a call from Lokey Infiniti, they say my clutch is on its way out, they said its not the throwout bearing they originally thought..... but its squeeking. No slipping, no grinding.... Any ideas? It sounds like the cable is rubbing on a rubber grommet on the firewall or something..... but only acting up on cool humid mornings? If the clutch is going out, it would act up all the time.
HELP!!
Old Dec 20, 2007 | 02:46 PM
g35rcr's Avatar
its not the clutch but the pedal...it just needs some grease
Old Dec 20, 2007 | 03:04 PM
Plat04G's Avatar
Sounds right...... they say thats not it. Im wondering if they are trying to pull the ol' stealership on me.
Old Dec 20, 2007 | 04:20 PM
kvangil's Avatar
I have the exact same problem. I lubed the pedal itself, and it still squeaked from underneath the car. Someone on here, in another thread i'm too lazy to search for, said that if you clean the clutch pedal linkage around the slave cylinder (attached to the tranny), it makes the noise go away. It's been too cold for me to go out in the garage to get under the car and do that...But mine comes and goes... Took it to the dealership and they too said that my clutch was "worn" and needed to be replaced--for $2000! I said no thanks, and walked away, since functionally it's fine. I'm waiting until it slips before I replace it, but the squeak's not too bad. being in the garage does amplify it though....
Old Dec 20, 2007 | 04:59 PM
Plat04G's Avatar
Awesome man. ill try that
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
AL8782
Oct 3, 2015 10:26 AM
Jpete
Sep 25, 2015 01:38 PM
bigmike
Sep 17, 2015 01:58 PM
jbmw002
Sep 10, 2015 12:54 AM
