2003 Coupe Rear Humming / Buzzing noise
Old Feb 9, 2008 | 12:15 AM
absurd's Avatar
Unhappy 2003 Sedan (ATX) Rear Humming / Buzzing noise
I've recently noticed that there is a fairly loud humming or a buzzing sound that comes from the rear of the car. Seems to happen between 30 - 50 mph. Its definetely not exhaust/engine noise because I can accelerate the car, pop it into neutral and kill the egine, and roll and still get the same hum. Also variying surfaces do not have any effect on the noise either , so its not tire noise.
Which makes me beleive its mechanical in nature. Axles, wheel bearings, diff?? Anyone have any ideas? THere is nothing wrong with the way the car drives, and outside the noise I cant fell any ill effects. Im going to take look if its not too cold on the weekend, see if there is anything obviously a miss. Meanwhile anyone have any ideas? Suggestions? Maybe someone can tell what I sould check while under there??
Thanks in advance
Old Feb 9, 2008 | 12:44 AM
crashnburn's Avatar
im kinda getting a squeak at low speeds from my rear...
Old Dec 10, 2008 | 01:35 AM
invisible's Avatar
its the tires..
Old Dec 10, 2008 | 01:57 AM
invisible's Avatar
ive had the same issue, but i took it to the dealer and they said that they had several owners complain of the same thing
Old Dec 10, 2008 | 02:07 AM
KSWAY's Avatar
sounds like wheel bearing to me..
Old Jan 4, 2009 | 10:13 PM
maxuz's Avatar
sorry to bump an old thread, but did you ever resolve this? i'm experiencing the same thing, except it sounds like its coming from the front driver-side. It only seems to happen between like 30-50, only for about the first 5 minutes i drive it, and only the first time i drive it each day. just like you, it doesn't matter if im accelerating, coasting, in neutral, braking, whatever.
It's an 04 coupe 6MT that i just bought used earlier this week. any insight would be appreciated.
Old Apr 7, 2010 | 01:26 PM
Deezflip's Avatar
bump,
my passenger rear has a constant humming at 60mph+, regardless of road, braking, turning, uneven pavement, bumps, etc.....like a noise-maker or a water bottle rubbing on a kid's bicycle tires but not as loud.
I'm thinking wheel bearing
...but wouldn't a bad wheel bearing start to make noises at lower speeds, gets more prominent as speeds increases, and the noise changes when braking/turning or even weaving the car left and right? any help would be appreciated
Old Apr 9, 2010 | 11:21 PM
DaveB's Avatar
Feathered tires. With the car parked, turn the wheel fully and run your hand over the inside edge of the tire. Does it feel bumpy? If so, that's the problem.
Old Nov 28, 2011 | 11:27 AM
obsdnoblivion's Avatar
I thought it was the tires too, but I got new ones and the sound was still there. I had them rotated a week ago and the sounds was still there then too. I was thinking it was the bearing like someone else said. How hard is it to replace a wheel/hub/whatever-it-is bearing?
Old Mar 24, 2015 | 02:44 PM
rvkempf's Avatar
Bump, has anyone else resolved or had this issue? I'm getting this humming noise on my '04 sedan MT, coming from the rear, that is loudest in the 30-45mph range, but has slowly been getting lourder and worse at different speeds. Started noticing it shortly after getting the tires changed, so that was my #1 theory, but I've never heard tires make a humming noise this loud before.
Old Mar 26, 2015 | 01:08 PM
Probably the bearings, man. I replaced one and shortly later replaced another. One of them I had to replace again after a few months, I think because I had gotten a cheap Chinese knock-off. I would recommend making sure you're buying Timken. (I had trouble with front rotors I bought from NAPA a couple of years back that were made in China, too, BTW)
rezendvous420
May 31, 2020 01:26 PM
TWASkyliner
Feb 8, 2020 08:00 PM
realtalk21
Jul 20, 2015 09:07 AM
driftsucky
Jul 15, 2015 12:38 PM
