Manual Tranny Fluid & Differential Fluid?
I've done searches and came up with multiple responses and recommendations. I am looking to change my tranny fluid and differential fluid as well. I want to use the OEM fluids. Can anyone point in the right direction as to which fluids to use, how much I will need of each, and where to find them? Thanks in advance.
I had the same question too, my only plan was, don't do it my self, just send it to a shop and have them do it, it doesn't cost that much, that way if ever any problems so you also have someone to blame.
Would I be able to use this in the diff? http://www.mynismo.com/images/?id=4609
And this in the tranny? http://www.mynismo.com/products/?id=3920
I need this done and want to make sure I buy the right stuff before I order. Thanks.
I just did this a few days ago. I used 2qts of Redline 75w90 for the diff and mixed 2qts of Redline MTL and 2qts of Redline MT90 for the transmisson. It took about 20 minutes to do on a lift. Very easy!
I did mine myself and it is easier than changing engine oil. I got my fluids from the dealership just so if there were problems Infiniti couldn't say I put the wrong stuff in.
370z, 75w90, diff, diffential, differential, fluid, g35, manual, oil, redline, tranny, transmission, type
