Clutch Sound
Clutch Sound
I'm not a clutch expert and don't really know much about G clutches. When let off of the clutch at idle I hear something that has to be the clutch. When I had my 72 Toyota Land Cruiser I could see that when I let off the clutch and let the engine idle the flywheel would spin until I engaged the clutch again. Does everyone else have a noticeable sound when letting off their clutch? I can't really explain the sound but i'm not sure if this is normal.
Not the "can't find it then grind it" concept but a noise like something is spinning. When i'm sitting at a traffic light with the clutch pedal pressed I hear nothing but the engine idling and when I let the pedal go there's a noise that I think would be abnormal. This is all while at a stop.
It sounds like a very low jet plane engine or vaccum sound. the G's/Z's are notorious for having "clutch rattle". It's a common problem for us 6mt owners. Very scary at first but you get used to it.
After market clutch sound
Hi, I just recently change my clutch to a ACT clutch /Alum Flywheel and well its doing a radling sound on first and second.. my mechanic said its normal.. also the dealer said the same thing I also called Stillen, which is the place where i bought it from.. and they also said it was normal, now my question is.. is it possible to lower the sound? or get rid of it? without having to change the flywheel to the stock one?
can you help me please
Originally Posted by martinS
I hear the same sound. I have a '04 6MT. At idle, clutch not depressed, I hear a very soft clicking sound. It is not even though. So this is normal? Is it hurting any part of the car?
my car does the same thing. so i dont know. i hope thats normal and its not hurting anything
The sound you guys r hearing is it like a diesel car kinda???? not as loud but kinda that sound??? I'm just asking cuz my car started to make that sound yesterday when i was at idle and my clutch not depressed but as soon as i pushed in the clutch to go into gear it would go away!! This Morning it just went away completely!!
