sticky JWT clutch!
Old Jun 1, 2008 | 11:47 PM
yoguh's Avatar
sticky JWT clutch!
I had posted this in the tech area, but not much help there, so I decided to post here to see if I could get any responses.
So, I had my clutch and flywheel both changed to the JWT combo maybe about a year ago, and recently it seems that the clutch pedal is a little sticky. It comes out a bit slow and then all of a sudden pops out. I had it checked by the Nissan dealership that installed it for me a while back, and they said it could be something to do with the springs on the pressure plates or something like that. Anyone know whether this is true or maybe other ways to test or fix it?
Old Jun 2, 2008 | 11:00 AM
tmounk's Avatar
I had the same issue with my Jwt on my 03 Z. I know not much help, but anything aftermarket will lead to problems like this. It's a sacrifice for performance.
Old Jun 2, 2008 | 07:01 PM
CreativeDesignZ's Avatar
your clutch fork was not properly lubricated with your clutch install most likely. same thing happens with mine as well =/
Old Jun 2, 2008 | 07:18 PM
oyoquem's Avatar
have you tried changing the clutch fluid? I had the same issue with the stock clutch and changing the fluid fixed it.
Old Jun 2, 2008 | 08:49 PM
LightsOut's Avatar
SIETESG
mine use to do that with the stock clutch and flywheel. i just added some spray wax.(i use it also for my motorcycle chain)
sprayed it directly into the clutch spring and wa la dont get stuck no more. try it might help.
Video Share
Jan 31, 2017 04:00 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Rose M
Oct 12, 2015 10:00 AM
AL8782
Oct 3, 2015 10:26 AM
