Torque converter question
Old May 23, 2004 | 03:17 AM
duckygirl's Avatar
Will the FX45 tq converter work on our car how or how about the VQ40's one?
Old May 24, 2004 | 10:12 AM
3point5SE_Auto's Avatar
Re: Torque converter question
Check the transmission numbers. I know the M45 and Q45 use the same tranny as the 5AT G, so if the one mated to the FX's VK45DE is the same then yes, but it won't make any difference.
If you want mo betta performance cough up the 500-700 dollars for a torque converter mod and send yours into Level Ten or someone like that.
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Goodyear F1 GS-D3's 225/55/17, Custom Intake Tube, HyperGround Kit, Magnaflow resonator.
Old May 24, 2004 | 10:43 AM
DaveO's Avatar
One quick question... Why?
DaveO
2003 G35 AT Sedan / DP / Willow / Premium / Sport
350Z T-Stat, Engine Cvr & Air Duct / Stillen CAI / Crawford Plenum
GrdGear Kit / TS ECM / E-Fans
Street Edge TC / B&M Cooler / Stillen Exhaust
Old May 26, 2004 | 07:12 PM
socalg35's Avatar
Good answer. Because noone else answers, just posts pictures.
Old May 26, 2004 | 08:30 PM
G35Tuning's Avatar
What kind of power gains are to be had from an aftermarket torque converter? Anyone happen to know?
Old May 27, 2004 | 02:51 AM
socalg35's Avatar
Just email edgeracingconvertors, they will answer all your questions (at least thats what I was told to do).
Old May 29, 2004 | 05:37 AM
GurgenPB's Avatar
NO real power gains - maybe 5 hp due to less slippage. The point of the TC is to make more power available at launch by stalling at a higher rpm. So, if you braketorque your car right now - the rpms will go up to 2200-2400. That's your stall. With, say, 3000 rpm TC, you will be launching at 3000 rpm rather than 2200. The obvious advantage here is that your car makes far mor power at 3000 rpm compare to 2200 rpm.
Gurgen
Old May 29, 2004 | 12:03 PM
Q45tech's Avatar
And slips more at cruise rpm adding more heat to ATF and tranny. For highway fuel economy TC are usally set for rpm that yields 55-65 mph in top gear.
But if you only drag race and do nothing else with car a good idea.
Old May 29, 2004 | 01:31 PM
Yes, once you start modding your G's tranny you should install as big a tranny cooler as they make. Other items to reduce the heat are a shift kit that increase line pressure (and therefore line flow) and a bulletproof tranny rebuild.
By the way bulletproof is only a relative term. and the tranny cooler should be common sense to anyone who does any research prior to upgrading a torque converter.
Old May 29, 2004 | 02:16 PM
GurgenPB's Avatar
What?
You are kidding me right? Out TCs are locking TCs. At cruise, the spragets in the TC lock and you have 0 loss! You are talking about the old school non-ocking TCs here. Ours definitely lock; nexttime you're on the freeway, try cruising in cruise control in 5th gear, shift back to 4th gear and back up to 5th. When the tranny shifts back up to 5th, the TC is still in the unlocked mode and over the next few seconds, while the TC is locking and you ar estill traveling at the set constant speed, you will seeyour rpms drop! check that out ...
Also, I in fact have less slippage now than I used to have ... my rpm drop @ TC locking went from 350 rpm to about 125-150 rpm - indicating a far tighter TC in the open, unlocked mode.
Gurgen
Old May 29, 2004 | 02:19 PM
GurgenPB's Avatar
Good point, 3point5,
I did install one. Whoever does it, just make sure you do it in series with the stock one.
Gurgen
<P ID="edit"><FONT class="small"><EM>Edited by gurgenpb on 05/29/04 12:04 PM.</EM></FONT></P>
yosip1115
Aug 26, 2015 10:46 AM
Mattdi
Aug 23, 2015 11:27 PM
Raven7
Aug 14, 2015 04:40 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
si_driver
Jul 14, 2015 12:29 PM
