High clutch engagement
Old Nov 18, 2008 | 08:47 PM
LBC77's Avatar
ok before you guys tell me to search I already did and no results .....I did the diy clutch adjustment and it didn't do anything my problem is when I dump the clutch it doesn't engage until all the way at the top any ideas?
Old Nov 18, 2008 | 10:28 PM
PTownG's Avatar
didn't search hard enough apparently. This works. The method you used not so much.
https://g35driver.com/forums/engine-...al-remedy.html
Old Jan 16, 2009 | 05:53 PM
lush1's Avatar
Could be your clutch is wearing out. As the disk wears, the friction point gets higher. Just got mine replaced. Clutch engages much closer to the floor now. It's taking me some time to get used to it. Your mileage is not a good indicator of clutch wear. Some people get 100K+, I got 32K on my 1st and 16K on my 2nd, and I don't drive like a maniac, race, ride the clutch or anything naughty. Have your clutch wear checked. If it's premature, don't wait till it slips. Order a different clutch and find a repair shop to install it. An Infiniti dealer will charge you $2400, more or less, to replace everything. Check your clutch fluid level too.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
bigmike
Sep 17, 2015 01:58 PM
mattdg35
Sep 14, 2015 11:28 AM
twentyeggs
Sep 11, 2015 03:58 PM
jbmw002
Sep 10, 2015 12:54 AM
