6th gear just started grinding??
Old Nov 24, 2008 | 09:14 PM
kohrt's Avatar
2003 coupe with 63000 miles - 6th gear just started grinding when it has rpms on it - if the rpms are low the shift is fine.
Any ideas or is it clutch time?
Old Nov 25, 2008 | 07:08 PM
Dmitry's Avatar
If the grind occurs when you are trying to engage the 6th gear with the shifter, then it could either be the clutch, or the synchronyser for that gear in the transmission. Usually if its a clutch issue, the grinding would occur in every gear. Im thinkin that you have a internal transmission problem ( 6th gear synchronyzer )
Old Nov 25, 2008 | 07:13 PM
partyman66's Avatar
You might want to talk to the dealership real real soon. I believe our stock powertrain warranty is 6 years or 70K miles. You're going to be close to nearing the end of your OEM powertrain warranty on both counts if you wait, and it would suck major buttocks to have to pay for a new tranny if your 6th gear synchros are trashed.
I'm guessing it probably is a synchro problem too with your 6th gear... otherwise, if it was a clutch-related problem, it would also do it in 2nd through 5th gear as well when you shifted into them and not just solely in 6th gear.
Have you ever changed your tranny fluid?
Old Mar 18, 2009 | 03:48 PM
kohrt's Avatar
Update - New Transmission
A new transmission at 66,400 miles - was the synchronizer for 6th gear. Known problem.
Took the service manager for a drive - complained about my November experience - new fly wheel and clutch plate - replaced as part of the drive train.
Now I need a paint job - 6 years old in Florida sun.
Old Mar 18, 2009 | 04:30 PM
uf20wop's Avatar
same thing i got when i had 6th gear grind
except i had 40,000 miles on my 04
Old Mar 18, 2009 | 07:28 PM
ttrank's Avatar
Grocery getter
I'm on tranny #2 as well. 2nd and 5th went out on me.
tiguy99
Mar 1, 2016 11:42 AM
Frostbite91
Aug 20, 2015 07:20 PM
jjohns2711
Aug 5, 2015 08:58 AM
tehmoonrulz
Jul 19, 2015 10:44 PM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
