should i change my flywheel???
Old Dec 22, 2008 | 04:03 PM
ma2dongpoong's Avatar
Hi all,
i have 03 coupe with 38500 miles, and im going to do change my clutch disk soon....
my question is do i have to replace flywheel?? and all other clutch assy.?
thanks~
Old Dec 22, 2008 | 04:10 PM
mIKE's Avatar
Pilot bearing, throwout bearing, clutch disk.
Pressure plate and flywheel... depends on their condition I suppose.
Old Dec 22, 2008 | 04:18 PM
flywheel??
i just went to a dealer, and they are just telling me i should replace eveything that you^ just told me... they haven't look through my car yet.
should i let them inspect them first before i purchase those parts and replace??
could i reinstall those parts if they are reusable(except clutch disk)??
thanks
Andy
Old Dec 22, 2008 | 04:35 PM
mIKE's Avatar
You don't want to reuse the two bearings; they're wear and tear items.
Generally, resurfacing the flywheel isn't recommended, and given that you're going through your clutch rather quickly, I'd lean toward replacing it, as you may have some heat spotting on it.
The pressure plate should be okay unless your clutch is COMPLETELY shot and you've been driving on it.
Old Dec 22, 2008 | 05:16 PM
ok
thanks!!!
11bEMT
May 27, 2022 03:13 PM
MooseLucifer
Sep 1, 2015 05:11 PM
yosip1115
Aug 26, 2015 10:46 AM
