Drilled Aluminum Pedals for 5AT
Old Jun 8, 2004 | 01:19 PM
bsgoren's Avatar
I've been thinking of buying the Infiniti Drilled Aluminum Pedals for my '04.5 G35 5AT, and wanted to know just how easy or difficult they are to install. I'm not impressed by all the aftermarket clip-on pedal kits, and PerformanceNissanParts.com has the real Infiniti aluminum pedal kit for $65.
I've read in other online forums that they can be a real pain to install (need a mirror, drilling, etc.)...has anyone installed the 5AT pedal kit themselves, what tools do they require, and how long did it take? Thanks.
2004.5 Infiniti G35 Sedan 5AT Black/Willow - Prem, R. Spoiler, Navi, Infiniti Sport Wheels
(basically Sport Package w/o stiffer suspension), Darkest Tint (this is FL afterall), Z Tube, K&N Filter
Old Jun 8, 2004 | 07:19 PM
GRider35c's Avatar
Re: Drilled Aluminum Pedals for 5AT
no drilling, easy install, 15 minutes?? the brake pedal is a pain in the a$$ though
04/BO/G/aero/splash/prem/perf/cc/22%tint
Old Jun 8, 2004 | 07:31 PM
Cruz's Avatar
Yeah the brake pedal is a bitch & you'll need a good 2 part epoxy to glue on the E brake pedal. But while you're installing the gas & gluing on the E brake pedal, let the brake pedal soak in a pot of really hot water & it'll make the rubber pliable & easier to work with.
XMLM
Old Jun 8, 2004 | 08:02 PM
bsgoren's Avatar
Thanks for the replies. Yes, I heard the brake pedal is a pain, but I may give it a try. Soaking the brake pedal in hot water...I'm assuming you mean the old rubber one to get it off? Thank you for the tips.
(basically Sport Package w/o stiffer suspension), Darkest Tint (this is FL afterall), Z Tube, K&N Filter<P ID="edit"><FONT class="small"><EM>Edited by bsgoren on 06/08/04 05:07 PM.</EM></FONT></P>
Old Jun 8, 2004 | 09:56 PM
MyGUnit's Avatar
he means the new one...it will make it easier to get around the emergency brake once the old one is off.....where is the cheapest you guys have seen the 5at pedal kit for?
Mitch
2004 G35C AT
Blk/Blk
Prem.Aero.Perf.Nav
Nav/TV Tuner w/ PS 2
2-10" Subs w/ Rockford Amp
Clear Corners
Pop Charger
Z-Tube
Old Jun 8, 2004 | 10:00 PM
subrobo's Avatar
took me 30-45 min...20min for the break padel....10 for the gas one(didnt read instruction) but its pretty easy though.
Old Jun 9, 2004 | 12:16 AM
Cruz's Avatar
No I meant the new brake pedal (pad). It's actually rubber w/ a drilled alum. face.
XMLM
Old Jun 9, 2004 | 08:27 AM
BlueGCoupe's Avatar
I remember trying to install that damn brake pedal. What a PITA. AFter about 30 minutes of trying to get it on, I walked away in frustration. My dad saw me, came over and popped it on in about 30 seconds.[img]/w3timages/icons/tongue.gif[/img] I guess I loosened it up for him [img]/w3timages/icons/smile.gif[/img]
Old Jun 9, 2004 | 08:51 AM
bsgoren's Avatar
Ah ha, I see. Soak the new brake pedal in hot water. Thanks. BTW - I will probably purchase them from PerformanceNissanParts.com for $65 for the 5AT kit (the least expensive I've seen so far).
Old Jun 9, 2004 | 01:16 PM
doorbell7942's Avatar
I got mine from ebay for less than $80,
I like ebay one cuz it had infiniti logo on it.
Gas pad was easy since no drilling required.
Break pad took awhile, had to drill 4 hole and it was made of tough metal, I use battery power tool and it took forever!!!
E. Break was easy only 2 hole.
Foot rest was easy no drilling.
I'll post a pic tommorrow
^_^
04c, Black, AT, PIAA, AL padel, smoked clear corner, 6th grounded-wire, z-tube/pop-charger, UR pully, Data grille & Gialla spoiler
Old Jun 10, 2004 | 09:57 PM
bsgoren's Avatar
Noticed the reason for the difference in price between EverythingG35.com and PerformanceNissanParts.com...the former Aluminum Pedal Kit (5AT) comes with the e-brake pedal while the latter does not. I think I like the uniformity of having all pedals in the drilled aluminum, so I may just purchase from EverythingG35.com for a few dollars more.
(basically Sport Package w/o stiffer suspension), Darkest Tint (this is FL afterall), Z Tube, K&N Filter<P ID="edit"><FONT class="small"><EM>Edited by bsgoren on 06/10/04 06:59 PM.</EM></FONT></P>
Old Jun 11, 2004 | 10:38 AM
here u go
^_^
Old Jun 11, 2004 | 10:44 AM
damn i need to clean these... hehe
^_^
Old Jun 11, 2004 | 01:40 PM
bsgoren's Avatar
Nice. I like the Infiniti logo.
Old Jun 25, 2004 | 03:25 AM
Risingsun124's Avatar
Something interesting I found today while putting on my pedals... The brake pedal slides on from the side... I lubed it up with some Windex, and slid it on... Just start at one side, making sure the top and bottom of the pad are both over the actual brake pedal, and slide it on... It will slide enough to allow the other side to "pop" into place... It took about 15 seconds to do... There are recesses on both sides of the top and bottom to allow this...
