I Absolutely HATE this transmission
Old Sep 29, 2010 | 11:27 PM
  #106
EnerOnE's Avatar
way to bring back a thread from the dead....
Old Sep 8, 2011 | 10:18 AM
  #107
Roman10111's Avatar
Question Throw-out bearing chattering...
I bought my car used 3 days ago and when i was inspecting it, it did not have the chattering noise and everything else was fine.clutch was perfect like its supposed to be and getting in gears was perfect and no problem. after i inspected the vehicle pretty good i took it for a test drive and i didn't hear the noise at all. All in all i inspected and drove away.i was driving for about an hour and stopped to get gas and realized then that the throwout bearing was chattering......fml......i didnt know what that noise was until i got it checked out by my cousin that works at infiniti and they found out that it was the bearing coming from the opposite side of the clutch and almost directly under the shifter.I was wondering are there and clutches that are pretty decent and dont make the chattering noise?i will also change out the bearing and try a aftermarket clutch. Ive always wanted this car and im about to be 17 and i payed for it with all my money up front. I love it and i dont want to sell it and im trying to figure out the best option for me to do with my car.thanks.
Old Sep 8, 2011 | 11:36 AM
  #108
SPEC-01's Avatar
If the noise is coming from the bearing then it isn't the result of the clutch. It sounds like you need to simply replace your TOB which will wear over time and need to be replaced anyway.
Old Sep 9, 2011 | 07:29 AM
  #109
Roman10111's Avatar
alright thanks spec!thats what i was thinking of doing while i have the trans out ill take a look at the clutch and see if its still good.
Old Sep 9, 2011 | 08:36 AM
  #110
slim17265's Avatar
try this, at 53000 miles I thought I would be doing something good by changing the gear oil......I drained and installed AMSOIL syn. immediately it was obvious at least on my car that this stuff was so slippery that I could BEAT the synchromesh and crash the gears...I removed it immediatly and put in MOBIL syn....it did the trick, no more problem
Old Sep 9, 2011 | 08:51 AM
  #111
Roman10111's Avatar
Slim: My car is at 50500 miles and the guy that previously owned it had an oil change and has been using mobil syn. I'll probably getting all my fluids changed and go from there.
Old Sep 9, 2011 | 10:01 AM
  #112
SPEC-01's Avatar
If you want me to help with assessment you can send some shots of the parts to me for viewing or post them here. Just let me know and I will be happy to help. Thanks
g.spot
May 9, 2016 10:54 PM
f22raptor
Mar 18, 2016 08:50 AM
DRG35R
Jan 31, 2016 07:14 AM
Row2k
Drivetrain
Dec 27, 2015 04:08 PM
