Automatic Transmission flush
Old Feb 5, 2009 | 06:05 PM
JOKER's Avatar
CLUB MODERATOR
where would be a good place to buy the tranny fluid (cuz my stealership is deff not a good place for that)
Old Feb 5, 2009 | 06:28 PM
joedaddy1's Avatar
www.mynismo.com
Old Feb 7, 2009 | 09:06 AM
IvoryPearl07G's Avatar
ok, yall have me wanting to flush my fluid. i am almost to 36k miles. I race this car everyweekend with lots of spirited driving and using the paddles.
it looks like i need 10qts of the nissan j-matic fluid from mynismo($7.85) and is the nissan 75w-140 best for the rear diff?
joker, where is the return hose located that i need to pull off? or if you can give me a page number to look at in the factory service manual, that would work as well. thanks for the heads up from everyone, my tranny has been shifting a little off lately.
Old Feb 8, 2009 | 11:53 PM
NaiveRapture's Avatar
I have 50K on mine and am getting some delayed shifts... I'm going to have the trans flushed soon. I just bought the car though and I'm not sure what, if any service has been done to it. Not much I'm guessing based on the way the car seems to have been taken care of. Any problem having super lube do it, or should I take it to a mechanic, to the dealership, where at??
Old Feb 13, 2009 | 08:11 PM
geronimomoe's Avatar
I would go with Amsoil gear lube for the rear differential.
As for the return hose, if my memory is correct, it's connected to the lower part of the radiator, on the driver's side.
Old Feb 13, 2009 | 08:27 PM
gr8huntr's Avatar
Just drain it you don't need a flush it's a waste of money...30k is just right to change it...
Old Feb 13, 2009 | 08:49 PM
erklep's Avatar
take it to your local nissan. theyll cut that price in half. only one hour labor...about 90-100$ depending on location
Old Feb 13, 2009 | 10:07 PM
GJ Hazlett's Avatar
An issue with getting it flushed with a machine is that you have to ask them to change the tranny filter...that's great you have clean fluid but if the filter hasn't been changed..well....
Old Feb 13, 2009 | 10:22 PM
erklep's Avatar
no tranny filters on our cars
Old Feb 14, 2009 | 12:45 AM
TurTLe*'s Avatar
who has the cheapest price on the matic J fluid?
999mp-mtj00p part number
mynismo.com has the cheapest price after shipping @ 7.85 after shipping it comes out to be $10.50 a bottle x 6.
scottdale had a similiar price totaling $11 a bottle x 6 shipped.
I haven't called around the dealerships in my area yet but i figure it will be about $10 a bottle in my area.
Old Feb 14, 2009 | 12:47 AM
DaveB's Avatar
A flush isn't necessary. The Nissan and Infiniti dealers in Kansas City don't do flushes with machines any more because the word from Nissan is it causes more problems. Additionally, all these shops say they simply drain the tranny every 30K miles even though Nissan really doesn't require a change until 60 or 70K miles.
A tranny fluid change will get you 3.1 QTs (measured myself). I didn't change my fluid until 60K miles. I bought 9 QTs of J-matic. Drained the tranny. Drove for 100 miles. Drained the tranny. Drove for another 100 miles. Drained the tranny. On every change, the fluid got pinker. Even after 60K miles and some decently hard driving on occasion, my G's fluid looked pretty good. I plan on draining the tranny every 30K miles and replacing with 3.1 QTs.
Note* If your G is shifting odd, replacing the fluid isn't going to fix the problem. There's something else going on.
Old Feb 14, 2009 | 02:24 AM
GJ Hazlett's Avatar
WOW...really? Not doubting you but how do you know and why not? What do they use to filter out the gunk?
Old Feb 14, 2009 | 03:11 AM
thanks for the info geronimo. i will do this in the near future.
Old Feb 14, 2009 | 01:22 PM
TheTick's Avatar
Why do I keep hearing that a flush can cause problems? I've always done drain and fills because I hear it's the safest and more than fine.
Old Feb 14, 2009 | 01:50 PM
  #30
TurTLe*'s Avatar
because most people flush them when its burnt and black, in other words too late. ATF is something not too many people are aware of. Oil change is common knowledge but thats about it. General public only know to take their car in when they need an oil change, check engine light is on or when they hear something funny. Aside from that most people never see a mechanic. I would never flush a trans that had black fluid, but some shops see black fluid and recommend it. its at the point of no return when the ATF is black because its burnt.
drain and fill only gets about 30-40% of the fluid but yes it is the safest way to do things. a flush at 30k wouldn't be so bad but still there is no telling exactly what fluids are being put in.
a dealership has 1 machine to do the ATF flush. you poor the fluid in and it does its thing. if the car before you had matic F and you need matic J well your most likely getting a bit of matic F in your car because rarely do they clean out the system. Just something to think about. I've been around dealerships and even worked for two.
