Traction control/ slip light coming on??
Old Feb 8, 2009 | 05:43 PM
DrewQ1's Avatar
Recently my coupe traction control will kick in when I am going on off an on ramps and exits...I won't have to be speeding and it will kick in and light will come on. The vdc is on it was doing it so someone said turn off the vdc and go through some turns and ramps and see if it does it again and the traction control was kicking in again. I don't see how I am losing traction or and I have new tires I put on a week ag I was told it could be the differential that's causing it. Would this also be covered under the powertrain warranty since my full warranty is over?
Any tips or advice please...thanks guys...its also 04 6mt coupe.
Old Feb 8, 2009 | 06:18 PM
bluemax189's Avatar
either that or maybe the clutch. when did you replace it last?
Old Feb 8, 2009 | 07:42 PM
DrewQ1's Avatar
Its not the clutch...that was replaced pretty recent..its only happening when i'm on the exit ramps...
Old Feb 9, 2009 | 08:39 AM
DrewQ1's Avatar
I've been searching and its seems to be because of me adding New rear tires...I am gonna order some new ones today and see if that solves the issue.
Old Feb 10, 2009 | 11:31 PM
M-azing.'s Avatar
ITS TIRES, any brand seems to do this or the ones i've had give um 2-3 weeks to brake in,
Old Feb 19, 2009 | 05:42 PM
lookthatsme's Avatar
does your traction just turn on and turn off or does it stay on the whole time until you turn your car off and turn it back on? I faced 2 issues one that my abs sensor was messed up and the light would turn on along with the abs light and stay on until i turn the car off. Also i bought new Falken 452 245/40/19 for the back and my slip would go on too on ramps until i bought new tires for the front also Falken 452 245/35/19
Old Feb 19, 2009 | 05:50 PM
orl-g's Avatar
tires sizes???
i was getting slip light when i was using different heights on oem 19's.
i think i had 225/30 in front and 245/40 in rear. now im riding 245/40 up front and 255/40 in rear and no problems.
im 04cpe 6mt as well.
Old Feb 19, 2009 | 10:08 PM
arsine's Avatar
It could be the brake pads. Mine would come on until I got them replaced
Old Feb 20, 2009 | 11:46 AM
beachygirl's Avatar
I put 2 new rear tires on & mine kicked in on corners I took every day...so I tend to agree with the new tire theory. About 200 miles later it stopped.
Old Feb 20, 2009 | 01:44 PM
G35IRLracer's Avatar
That's really weird... I'll have to keep that in mind when I buy new tires.
Old Feb 22, 2009 | 01:45 PM
bwilbur1982's Avatar
I have the same problem doing 70ish around mountain roads brand new tires the last 2 times i put new tires it has done it but my worn out stock tires held the roads at about 90-100 no problem. Is this something that will go away with some miles on the tires? I didnt notice it after a while on the first new set but then again i slowed down around the corners after the first couple times.
Old Feb 23, 2009 | 01:36 PM
cydal's Avatar
this happened to me before when i changed tires. just do a alignment and problem goes away.
Old Feb 24, 2009 | 04:34 PM
orl-g's Avatar
notice how everyone mentions tires ...
make sure you have proper size / height combination for the staggered wheels.
having extremely different size tires changes the speed betweeen front and rear wheels, which confuses the vdc and trips slip light. correct me if im wrong.
Old Feb 25, 2009 | 01:46 PM
i ran stock size tires and they still slipped so i dont think that would be the issue on mine?
Old Apr 14, 2011 | 10:44 PM
marshallpre1's Avatar
Bringing this back up from the dead. I have really worn rear tires that I just replaced and just got an alignment done from the Nissan dealer by me. Whenever I'm making a sweeping right, the vdc comes on and starts applying brakes. WTF. It's very intrusive and makes it very difficult to drive. My old RB25 S13 didn't have traction control and neither does my 500whp Supra, so it's not like I don't know how to drive without it on. Is it really just the tires? Or brake fluid?
Thanks,
Jeremy
