11lbs flywheel? yes or no?
Old Mar 5, 2009 | 06:20 PM
G35-31's Avatar
im goin to get a clutch kit and im thinking of putting an 11lbs flywheel in it whats the advantages and disadvantages of such a light flywheel like this?
i have a choice of a 11lbs or an 18lbs
Old Mar 5, 2009 | 08:50 PM
djamps's Avatar
The lighter the flywheel the more noisy and jerky it's going to get, but the engine will rev a bit quicker. Mine sounds like a mack truck under 2krpm since the swap with a 13lb. You also might get some shudder (shaking) during engagement.
Old Mar 5, 2009 | 08:59 PM
Mr_pharmD's Avatar
what is stock flywheel weight?
Old Mar 5, 2009 | 09:01 PM
G35-31's Avatar
must rev like a beast though?
stock flywheel is like 31lbs
Old Mar 5, 2009 | 09:04 PM
dofu's Avatar
20 Year Member
About 30lbs...
Old Mar 5, 2009 | 09:09 PM
PAIXAO's Avatar
Personally, I wouldn't put my engine through the abuse. Our flywheels are dual mass flywheels. I have yet to find an aftermarket flywheel I would use.
Old Mar 5, 2009 | 09:41 PM
GreenGoblin's Avatar
The goblin resurrection
It will probally chatter like a ****
Old Mar 5, 2009 | 09:44 PM
G35-31's Avatar
green you have one in your car?
Old Mar 5, 2009 | 09:47 PM
dofu's Avatar
20 Year Member
It will chatter like a mutherfocker, you will instantly feel the revs climbing faster, but that feeling goes away really soon, after you get used to it.
Old Mar 5, 2009 | 09:52 PM
G35-31's Avatar
so 18 better then?
Old Mar 5, 2009 | 09:53 PM
dofu's Avatar
20 Year Member
It depends on what you mean by "better"
I have a 12lb because it's the lightest I could find at the time.
Old Mar 5, 2009 | 09:57 PM
G35-31's Avatar
do you spinn like crazy shifting into 2nd?
Old Mar 5, 2009 | 10:00 PM
dofu's Avatar
20 Year Member
Only if I gun it
Old Mar 6, 2009 | 12:46 PM
Jeff92se's Avatar
Red Card Crew
How come no one argues the dangers of a lightened flywheel when the lightened pullies are so bad?
Old Mar 6, 2009 | 01:00 PM
djamps's Avatar
Not sure what the danger of a light flywheel would be...would be interested to hear about someone who got burned by a light flywheel. dual mass it's more to reduce noise and vibration than anything.
