clutch or tranny? help!
Old Mar 9, 2009 | 10:04 PM
fastGkid's Avatar
ok guys tonight i threw it into reverse to back into my driveway and all of a sudden my clutch stuck to the floor when i let out to back up. clutch has not been slipping or any sign that its going. i then had to pull the clutch out with my foot behind it to disengage it and then i put it into neutral. it will now not get into a gear but will engage but when engages it sticks to the floor.
is this something with the tranny or clutch by the sound of it?
what could it be i really hate to pay for something so expensive
thanks
Old Mar 9, 2009 | 11:12 PM
prj3ctm4yh3m's Avatar
master cylinder or slave cylinder is gone. look under the car for a nice puddle.
Old Mar 10, 2009 | 01:40 AM
SILVERSURFERG35's Avatar
Ditto !!
Old Mar 10, 2009 | 08:54 AM
SPEC-01's Avatar
Correct, it is most likely a Slave or Master Cylinder issue, and though problems of this type can lead the Slave Cylinder to pop (blowing out its seals) you can also have issues of this type if the Slave or Master a bypassing fluid internally. If the seals go then you will have a puddle. If the assemblies are bypassing fluid internally you will not have a puddle. Check for the obvious puddles first. If you don't see evidence of a leak on the ground then check the firewall near the master cylinder. If it is the Master you can find fluid both in the engine bay and in the cars floor-board. Check it out and let us know what you find.
Old Mar 10, 2009 | 10:38 AM
fastGkid's Avatar
thanks for the help i will look today
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
alessandro
Oct 8, 2015 09:29 AM
AL8782
Oct 3, 2015 10:26 AM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
Jpete
Sep 25, 2015 01:38 PM
