I NEED the actual name for this part!!!
Old Mar 10, 2009 | 12:16 AM
TVang's Avatar
I keep referring to it as clutch sensor, but the guy at the store has no idea what I'm talking about, so I'll ask you guys so I can buy the right dang piece!
I need to replace that sensor that is attached to your clutch. Crap, I don't know how else to explain, it's the one that basically tells your ecu that the clutch is engaged and now you can turn the ignition and start the car.
Hope you guys know what i mean.
Old Mar 10, 2009 | 01:57 AM
nismo240r's Avatar
Originally Posted by TVang
but the guy at the store . . .
store. . .?
try a dealership. . .
I've got a fsm on my laptop, once it's warmed up i'll post up the part # if no one else hasn't yet. . .
Old Mar 10, 2009 | 02:41 AM
TVang's Avatar
Alright, thanks! =)
Old Mar 10, 2009 | 08:49 AM
SPEC-01's Avatar
Clutch Interlock Switch
I believe that you are referencing the switch that can be found at the bottom of your clutch pedal travel. This is the switch that allows the car to start when the clutch pedal is depressed. It is called the Clutch Interlock Switch. I am not sure of the actual part number but the dealership should be able to provide this info based on the name provided above. Let me know if you need anything else. Thanks!
NemesisGee
Aug 11, 2015 07:10 PM
Rehman2009
Jul 27, 2015 03:23 AM
