clutch help needed.
Old Mar 18, 2009 | 06:28 PM
RST531's Avatar
clutch help needed.
anyone know of a local shop to buy a Exedy OEM Replacement Clutch Kit?
i checked performance nissan, and no luck. my clutch starting slipping bad last night and i need to fix asap.
if not, i was thinking to upgrade to a nismo clutch and nismo pressure plate. if i do what else is needed to install those?
Old Mar 18, 2009 | 06:30 PM
ttrank's Avatar
Grocery getter
What about JWT?
Old Mar 18, 2009 | 06:36 PM
RST531's Avatar
ya i saw that too, but online i found the Exedy OEM Replacement Clutch Kit for about $300. which is $100 less than the JWT and that is $150 less than nismo. well i can go either nismo or jwt, but on mynismo they also just show the JWT with a clutch and pressure plate. is there anything else needed for the install?? like Release Bearing, Pilot Bearing, or Aligning Tool?
Old Mar 18, 2009 | 06:44 PM
RST531's Avatar
whats is the difference between Nismo and JWT besides the price? i havent really seen reviews on Nismo.
Old Mar 18, 2009 | 08:33 PM
05REV's Avatar
i didnt even know nismo made a clutch kit thats news to me. but o well im gonna do the JWT when i need a clutch
Old Mar 18, 2009 | 08:47 PM
RST531's Avatar
Ya i just might do the same now. but does anyone know if i need anything else when i drop my car off at a shop with the JWT (clutch and pressure plate)? ex: Release Bearing, Pilot Bearing, or Aligning Tool?
Old Mar 18, 2009 | 08:49 PM
05REV's Avatar
when you buy the clutch if comes with the stuff you need at least thats what the website says
Old Mar 18, 2009 | 08:55 PM
RST531's Avatar
05rev - ok great!! thansk!!
also i just spoke to the shop that will do the install and now they saying i may need a new flywheel if its burnt (?) and local shops wont resurface them in my area??
Old Mar 18, 2009 | 09:51 PM
1SlowSedan's Avatar
Do you have the oem flywheel? If I'm not mistaken you can't resurface the oem dual mass flywheel.
Old Mar 18, 2009 | 10:18 PM
RST531's Avatar
^^ correct. i still have the original flywheel.
Old Mar 18, 2009 | 10:46 PM
1SlowSedan's Avatar
you're going to have to buy a new flywheel brotha
Old Mar 18, 2009 | 11:02 PM
RST531's Avatar
doh! i guess i should look into getting the jwt flywheel too then.
RST531's Avatar
thanks everyone.
Old Mar 18, 2009 | 11:05 PM
1SlowSedan's Avatar
check out ACT prolites, pretty quiet for a single mass. idk do some search about clutch chatter.
Old Mar 20, 2009 | 11:02 PM
VolkZ's Avatar
yes u can, they use a circular platform with a circular grinding stone, and keep it cool with water
edit: if u need it done pm me i know a place
Here is what it looks like: http://i363.photobucket.com/albums/o...ai/Picture.jpg
