10mm hex key for differential / transfer bolt...
Old Apr 3, 2009 | 11:09 PM
mikeee2's Avatar
Hi,
I read that to get the differential / transfer drain bolts out, you need 10mm hex key. I have a craftsman 154 mechanic set and I can't seem to find this 10mm hex key. Maybe I don't have it? Or am I not looking at the sockets correctly?
http://www.sears.com/shc/s/p_10153_1...5154000P?mv=rr
Set includes:
# Sockets
11 - 6pt. 1/4 in. Drive Standard Sockets (5/32, 3/16, 7/32, 1/4, 9/32, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16 in.)
12 - 6pt. 1/4 in. Drive Metric Sockets (4mm, 5mm, 5.5mm, 6mm, 7mm, 8mm, 9mm, 10mm, 11mm, 12mm, 13mm, 14mm)
5 - 6pt. 1/4 in. Drive Standard Deep Sockets (3/16, 7/32, 1/4, 9/32, 5/16 in.)
5 - 6pt. 1/4 in. Drive Metric Deep Sockets (7mm, 8mm, 9mm, 10mm, 11mm)
10 - 6pt. 3/8 in. Drive Standard Sockets (1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16 in.)
13 - 6pt. 3/8 in. Drive Metric Sockets (6mm, 7mm, 8mm, 9mm, 10mm, 11mm, 12mm, 13mm, 14mm, 15mm, 16mm, 17mm, 18mm)
6 - 12pt. 3/8 in. Drive Standard Sockets (5/16, 3/8, 7/16, 1/2, 9/16, 5/8 in.)
6 - 12pt. 3/8 in. Drive Metric Sockets (10mm, 12mm, 13mm, 14mm, 15mm, 17mm)
6 - 6pt. 3/8 in. Drive Standard Deep Sockets (7/16, 1/2, 9/16, 5/8, 11/16, 3/4 in.)
6 - 6pt. 3/8 in. Drive Metric Deep Sockets (10mm, 12mm, 13mm, 14mm, 15mm, 18mm)
6 - 6pt. 1/2 in. Drive Standard Sockets (7/16, 1/2, 9/16, 5/8, 11/16, 3/4 in.)
6 - 6pt. 1/2 in. Drive Metric Sockets (14mm, 15mm, 16mm, 17mm, 18mm, 19mm)
5/8 in. Spark Plug Socket
# Combination Wrenches
6 - Inch (1/4, 5/16, 3/8, 7/16, 1/2, 9/16 in.)
6 - Metric (9mm, 10mm, 12mm, 13mm, 14mm, 15mm)
# Extensions
3 in. Extension Bar with 1/4 in. Drive
3 in. Extension Bar with 3/8 in. Drive
# Hex Keys
11 pc. Inch
11 pc. Metric
# Additional Tools
1/4, 3/8 and 1/2 in. Quick Release Ratchet
Magnetic Handle
9 pc. Screwdriver Bit Set
12 pc. Nut Driver Bit Set
Thanks...
Old Apr 3, 2009 | 11:10 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
you wont have it in a sears kit. You'd have to buy it separately. It is normally a 10mm hex attached to a 3/8" adapter.
-GP-
Old Apr 3, 2009 | 11:16 PM
mikeee2's Avatar
-GP-
Like this?
http://www.sears.com/shc/s/p_10153_1...yword=10mm+hex
Old Apr 3, 2009 | 11:17 PM
GEE35FX's Avatar
Originally Posted by mikeee2
Hi,
Set includes:
# Hex Keys
11 pc. Inch
11 pc. Metric
# Additional Tools
Thanks...
Bobby if it is in your set it could be in with the 11pc metric allen wrench set.
It would be good to pick up a 3/8 drive socket with a 10mm hex key in it, as Grant said. (Like in your picture)
Old Apr 3, 2009 | 11:26 PM
exactly. same one i have.
-GP-
Old Apr 3, 2009 | 11:44 PM
mikeee2's Avatar
Wayne, the metric set meaning the L shape allens right? Those would be too weak to unbolt anything I think.
mikeee2's Avatar
-GP-
Great. Will get a craftsman. Thanks...
Old Apr 3, 2009 | 11:49 PM
GEE35FX's Avatar
They are pretty stong Bobby, sometimes when I am using them at work and I need a bit more leverage I use a small pipe to slide over it to get a bit more leverage (within reason) We used them all the time where I worked.
Old Apr 4, 2009 | 12:00 AM
mikeee2's Avatar
Hmm...really? They seem really thin/fragile to me. Maybe I just have bad experience with them where I usually ruin bolts with them. The only time I use them is if I buy something from Ikea because they come with the allen keys.
Old Apr 4, 2009 | 12:06 AM
GEE35FX's Avatar
Quite often the Allen keys that come with stuff like that are low quality metal. Good quality allen keys will take quite a bit.
Old Apr 4, 2009 | 01:39 AM
TurTLe*'s Avatar
the L wrench will not cut it.
i have a snap on set
http://buy1.snapon.com/catalog/item....re&dir=catalog
the c-man socket will do as well. for the weekend wrencher its something you rarely use.
Old Apr 4, 2009 | 01:41 AM
kailep's Avatar
Like others said, hex is usually not in a kit. I bought the craftsman for like $5. I rather spend the 5 bucks than using the skinny allen wrench. Maybe it'll work but better be safe than sorry.
Old Apr 4, 2009 | 01:42 AM
mikeee2's Avatar
Wow...that's an expensive set.
Old Apr 4, 2009 | 02:03 AM
TurTLe*'s Avatar
when i bought them, it paid for itself the same week. Instead of paying people to go things you spend it on tools, well thats the DIY guy way.
if i never worked at a dealership i wouldn't of bought it. i would of stuck with the $50 c-man set.
Old Apr 4, 2009 | 07:26 AM
jimNC's Avatar
Get a 10mm hex 3/8 socket. If you use an L-wrench you might be able to get it off (by sliding something over the handle for more leverage) but if you use a socket you can actually torque it back on there at the correct setting (25 ft-lb).
I've got a pretty large socket set but no hex sockets so I just bought this one singly. Just hope I don't lose it since I don't use it for anything else
If you are gonna use an L-wrench then make sure you break the fill plug first, in case you can't break the drain plug. Probably should do it in that order regardless.
Edit: if you have a torque wrench it is probably 1/2" drive so either get a 1/2" socket or make sure you have a 1/2" to 3/8" adapter.
