clutch going into neutral?
Old Apr 8, 2009 | 12:51 AM
rob40wilson03's Avatar
so i was wondering the other day, is it necessary to push in the clutch when you're shifting into neutral (like when stopping at a light)? i ALWAYS use the clutch when i do this, but couldnt decide if it's really necessary since the no syncros are being used like they would be when shifting into another gear
just curious... what do you guys think?
Old Apr 8, 2009 | 12:53 AM
elayman's Avatar
I don't think you can move the shifter from 1st to neutral without the clutch?
Old Apr 8, 2009 | 01:02 AM
35gsleeper's Avatar
If u want to grind away your shifter..mess up the teeth on the fly-wheel and damage your clutch..go ahead..how long have u been driving a manual tranny..u should no better..the only way you can avoid problems with shifting without using your clutch is to right on the certain RPM number that is made for a down shift or up shift.
magnetism80
Feb 1, 2019 10:00 AM
Thebaws11
Nov 30, 2016 12:54 PM
AL8782
Oct 3, 2015 10:26 AM
Jpete
Sep 25, 2015 01:38 PM
Since 1983
Sep 19, 2015 10:26 AM
