transmission valve body, control valve assembly
Old Apr 20, 2009 | 02:21 PM
davey_98's Avatar
Hey guys,
Has anyone, with an AT 05-06 RWD, who's had that shudder vibration shake at or around 40mph gotten replaced the transmission valve body (control valve assembly)? As stated in the service bulletin.
Wondering if it worked and how long you were in the shop.
Old Apr 21, 2009 | 09:15 AM
davey_98's Avatar
anyone?
Old Apr 21, 2009 | 09:21 AM
aBLUEg35's Avatar
no, how many miles do you have? i've got an 06 with 20,000 and i havent had this happen to me
Old Apr 21, 2009 | 09:50 AM
sloppymax's Avatar
I had mine replaced over a year ago. Going up hill, the car would shudder around 40-42 mph. They had to order the vb. Took about week and a half. They gave me a loaner and had it finished the following day. The line pressure actually increased as recorded by the Autoenginuity program I was using at the time. I do not remember the actual increases though. Worked great, felt like more crisp shifts afterwards and no more shuddering. Also essentially got a drain and refill on the ATF because of having to drop the pan to get to the VB.
Old Apr 21, 2009 | 09:53 AM
davey_98's Avatar
Thanks for the info sloppymax
i got 33,000 miles on mine
Old Apr 21, 2009 | 10:04 AM
aBLUEg35's Avatar
oh man i know what you guys mean now... mine does it when your just rolling around 40ish but if you downshift it goes away... how do i explain this to the dealership?
Old Apr 21, 2009 | 10:12 AM
sloppymax's Avatar
I took the advisor for a ride in the passenger seat and had a tech in the back. Found a decent hill, went 40mph and it started. That was enough for them. I had the TSB number but luckily it is a good dealer and they gave no hassles.
Old Apr 21, 2009 | 10:13 AM
sloppymax's Avatar
I think I had around 15,000 when I first noticed it. At first it was intermittent then started occuring more often. Finally got it replaced around 20k when I read about the TSB.
Old Nov 10, 2009 | 10:27 AM
echang0501's Avatar
cam someone please give me the tsb number please please please????
Old Jun 30, 2010 | 09:59 PM
aBLUEg35's Avatar
i need some help because i did the transgo and now my car does it way worse.... what part do i replace seeing as my warranty bit the dust with the vortech!
Old Jun 30, 2010 | 10:03 PM
CLyons0203's Avatar
I thought the transgo was an upgraded valve body
Old Jul 8, 2010 | 04:52 PM
aBLUEg35's Avatar
its not as bad after about 100mi but it still shutters a lil
Old Jul 10, 2010 | 04:29 PM
aBLUEg35's Avatar
anyone have any ideas about this?
Old Jul 13, 2010 | 11:15 AM
Tollboothwilley's Avatar
Is the valve body a different design or is it just different solenoids? I've never heard of this problem.
Old Jul 20, 2010 | 07:30 PM
aBLUEg35's Avatar
well the car did the shuttering a little bit before but the transgo increses line pressure so now insted of only doing it while cruising around at 40mph in 5th it does it does it more frequently.. im not a trans guy so im not sure of just what part is replaced when the dealership fixes the issue?
