rumbling noise 6MT help!
Old Sep 28, 2009 | 05:51 PM
djamps's Avatar
Originally Posted by Chubbs
^^^ I have that same problem. It's also causing my car to idle weird.
Every time is clanks, the idle sounds like it misses a little bit.
The clank is actually caused by the misfire. I had the exact same thing when I was stock.
Old Sep 28, 2009 | 07:11 PM
Chubbs's Avatar
Ive got brand new plugs in it. I think my injectors are dirty...U think the timing is off?
Old Sep 28, 2009 | 09:41 PM
djamps's Avatar
A stock VQ35 has a slight misfire at idle. Mine did it from the day I drove it off the lot. It went away after I went twin turbo (go figure lol).
Old Sep 29, 2009 | 12:23 PM
SPEC-01's Avatar
Guys, It looks like a few of you have this question and though I don't see anyone referencing our parts in this thread I thought it may help to get some insight from a manufacture. When you replace the stock dual-mass flywheel with a lightened (non-dampened) flywheel you are going to hear what is commonly refered to as "gear noise" or "gear lash".
This sound, which is actually better understood as harmonics or vibration, originates in the transmission and occurs as a result of the inter-play of the gear set and the lay-shaft gear. This sound is typically dampened by the OE dual-mass flywheel and without it the sound will be more evident especially under high-load (as one would see at low RPM and high throttle opening).
This should does not evidnece an issue with the parts or the transmission and is in fact normal when dampening is removed. That being said you can always opt to use the OE duall-mass flywheel or an aftermarket steel replacement flywheel which will both provide greater noise supression. I hope this info helps. Please let me know if you have any further questions. Thanks,
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
RWDguy4238
Sep 30, 2015 12:13 AM
alinero718
Sep 27, 2015 09:35 PM
