rumbling noise 6MT help!
Old Jun 9, 2009 | 04:25 PM
songman9111's Avatar
hello,
just wondering. I've been searching the site and looking for a possible thread that could assist but couldn't find anything that describes what I'm hearing or going through mentally.....
I have a 2003 G35 Sedan 6MT and I just recently replaced the clutch (exedy stage 1) and the flywheel (Clutchmasters light weight). After doing so when changing the gear from a low RPM there is a fairly loud rumble and vibration which sounds like it is coming from the tranny. So I accelerate from 1st, at an RPM lower then 1500 and the rumbling noise and vibration begins, this happens during all gears and even worse in reverse. if I am at a higher RPM in 1st accelerating aver 1500RPM the car goes as normal and switching gears normally it works fine, just if I let the RPM's drop below 1500RPM is when you feel the rumble and vibration. In reverse I need to be higher then 2500RPM in order not to feel the rumble, but I dont want to burn out my clutch.
I've been to 3 mechanics: the first says it's the flywheel, b/c there is no damper on after market flywheels it will rumble.
second says the clutch has to "break in"
3rd says it is the gearbox and the whole tranny has to be replaced.
Please let me know if anyone else has had this same experience or know what the issue is?
I can't stand it and want to drive the car into a brick wall, my last resort is the dealership which I'm scheduled for tomorrow, but I know they are going to r*pe me....
any ideas?
Old Jun 20, 2009 | 01:52 AM
boostedforlife's Avatar
yeah i just had a lightweight flywheel put on bc i needed a new clutch and i didnt want to buy an expensive oem dual mass. i have the same problem. the dealer says its normal but i think its ridiculous that the transmission would make so much noise. anyone else have any ideas?
btw i have an 06 6-speed
Old Jun 21, 2009 | 12:30 AM
G35fromTO's Avatar
What the OP describes I exp on one of the cars I test drove while searching to buy one. The seller told me it was also "normal" and the clutch needs to be "broken in". He actually installed the Exedy Stage 1 as well.
I don't buy the whole normal thing... go on Exedy's site and they have a PDF file on there that lists various problems and there possible causes. There can be a few for the clutch chatter you are experiencing... I think thats what you have based on what you described.
Old Jun 21, 2009 | 12:38 AM
yea i dont believe it either, i have had a stage 4 race clutch for a 12 second car i had before and i had no problems.
soo i did some searching on my350z and apparently its what happens when you have a single stage flywheel. i dont see why going from a dual to single makes the noise, what about all of the evos civics subys etc other cars, that come with a single fly, they dont make the noise when you put a lighter one on..... go figure why nissan would make such a noisy tranny that needs the fly to absorb it.
Old Jun 29, 2009 | 10:09 AM
DickyDanG35's Avatar
Brakes
Originally Posted by songman9111
hello,
any ideas?
I bought the same Clutch and Flywheel..... I have the same problem! Why is that? I dont know....I'm tryin to find the problem right now! I wonder if I have to brake in my clutch or what but this noise is driving me Insane!!!!!!
If anyone know what I can do please help me out! Dont want to spend another 400 for them to install the flywheel on my car.....Thanks!
Old Jun 29, 2009 | 11:51 AM
its normal bro.......
Old Jun 29, 2009 | 06:41 PM
its not a normal chadder...its pretty darn loud! When people asking me whats wrong w/ my car, its pretty bad. My Factory clutch & flywheel made noise but it didnt really bother me til i installed the Exedy clutch & flywheel....it even rumbles when its sitting still, until i step on the clutch it get quite agian...
Old Jun 29, 2009 | 06:54 PM
nghiars's Avatar
how much lighter is the Exedy Flywheel vs the OEM dual mass flywheel?
Old Jun 30, 2009 | 03:21 AM
tonke73's Avatar
Did they replace your throw-out bearing? That sounds like the throw-out bearing is going bad.
Old Jul 2, 2009 | 01:22 AM
Thats what I was thinking..... Its in the shop now...getting that changed out tomorrow...lets hope thats what it is...
Old Jul 5, 2009 | 12:42 AM
Dima898989's Avatar
Very curious as to what they will say, have the same exact problem with mine. Have a z1 performance street clutch and z1 lightweight flywheel. People always think something is wrong with the car and I'm starting to believe them, it's driving me crazy! Anyone have more knowledgeable info on this matter?
Old Jul 6, 2009 | 10:45 AM
djamps's Avatar
It's normal my friend. The sooner you accept it the better. I'll bet you $10,000 a new tranny isn't going to fix it, and an extra $1000 that it actually gets worse! LOL
PS My 12lb flywheel sounds like a mack truck off the line. I starting to like the funny looks I get, especially when they end up in the rear view mirror haha.
Old Jul 6, 2009 | 01:23 PM
Polaren's Avatar
Got the same issue with mine Stg 2 clutch, 12lb flywheel.
Just got used to it. Always get weird looks off lights from the noise lol. Ah well.
Old Sep 24, 2009 | 08:54 PM
Stephan87's Avatar
I have a similar question to those above; my tranny makes a rattling sound when at idle, ive been told its the duel mass flywheel and its a common issue among all G MT's but i was wondering if anyone else has had the same issue. it mostly happens after it wars up and sometimes a first start up ( its like a clanking sound very annoying and concerning) any ideas???
Old Sep 28, 2009 | 04:31 PM
Chubbs's Avatar
^^^ I have that same problem. It's also causing my car to idle weird.
Every time is clanks, the idle sounds like it misses a little bit.
